Ground clearance 458 Speciale | FerrariChat
Discussion in '458 Italia/488/F8' started by glob1971, Sep 28, 2015.
  1. glob1971
    glob1971 Formula Junior
    Jul 3, 2011
    442
    Czech Republic
    #1 glob1971, Sep 28, 2015
    Hello,
    I am checking if my new 458 Speciale will fit in my underground garage, does someone know the ground clearance (and idealy A, B and C dimensions of the picture enclosed) ? Big thanks in advance.
  2. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    What I get on mine (could be off no more than 1/16" to 1/8"):
    A = 5"
    B = 3 and 7/8"
    Both of these measurements are to the bottom of the rubber bumper (which is about 1")
    C = 5 and 3/8"
    Hope these help.
    Maybe someone else will confirm with a second set of measurements.
  3. MuratC
    MuratC Formula Junior
    Jul 6, 2014
    539
    Istanbul, Turkey
    Don't know the heights at your points, but according to factory, the ground clearance at master points are 133.6 ± 5mm for the front and 159.1 ± 5mm at the rear
  4. glob1971
    Jul 3, 2011
    442
    Czech Republic
    Thanks abz and MuratC for your answers, but there is a big difference between those values 😱. I undersrand abz you measured your car, might be more accurate data. Maybe another set of measurement to confirm ? Thanks.
  5. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    So. Cal and No. Utah
    Rick
    Here's another possible complication. I believe that US Speciales are noticeably higher than Euro Speciales. Mine looks like an SUV so I'm getting it lowered 15-20mm :)
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,724
    These points are the centerline of the lower chassis pick up point bolts. This is several inches farther off the ground than the lowest point on the chassis.
  7. aviator88
    aviator88 Karting
    May 13, 2015
    77
    Johannesburg
    What can be more important are approach angles and departure angles, rather than actual clearance. So the nature of the driveway/ramp must be taken into account. Try measuring by placing a rod from where the tyre contacts the road to the lower lip of the front/rear bodywork to get an idea of the angle. It worked for me.
  8. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    #8 720, Sep 30, 2015
    I have nightmares everytime I think of this guy's driveway :)
  9. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    Certainly could never go straight in!
  10. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    +1
  11. joaomsb92
    joaomsb92 Rookie
    Feb 3, 2010
    13
    Is it easy to find the right angle for the most common "obstacles" you might find along the road? I mean, is it intuitive?
  12. Eilig
    Eilig F1 Rookie
    4,115
    Tänzelndes Pferd
    #12 Eilig, Sep 30, 2015
  13. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    That has to be the worst I have ever seen.
    How could anyone build such a driveway?
    Certainly not for a car!!!
  14. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    That one wins the prize!!! You'd think there would be some building code that would prohibit such an extreme driveway. I guess if you owned a tank you'd be fine. LOL.
  15. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    My Gawd, if you clear the sidewalk ..... You will be high centered half way into the garage ?????
  16. SE_Speciale
    SE_Speciale Rookie
    Sep 19, 2015
    27
    Sweden
    Thomas
    Don't even think my Range Rover could drive up that hill :D And wouldn't even try doing so in my Speciale. Already had enough problems, even got stock on a hilltop at a drive-in once and when I finally got free, I managed to scrap the entire chassis leaving. But again, it's just a car and it didn't brake down.
  17. neil-f
    neil-f Karting
    Feb 6, 2008
    223
    That drive is not fit for purpose!!! Incredible...
  18. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,715
    ESP
    Bas
    That's one of the dumbest driveways I've ever seen.
  19. spyderman
    spyderman Formula 3
    1,622
    Toronto - Canada
    Spyderman
    That picture can't be real...
  20. Eilig
    Eilig F1 Rookie
    4,115
    Tänzelndes Pferd
    #20 Eilig, Oct 1, 2015
  21. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    By the looks of that guy trying to walk up,
    I think they need to build an escalator.
