Ground clearance | FerrariChat
Ground clearance
Discussion in 'Boxers/TR/M' started by louis13, Nov 1, 2011.
  1. louis13
    louis13 Karting
    Aug 28, 2005
    51
    Marseille, France
    Louis
    Hello !
    I have some trouble with the ground clearance of my 89' Testarossa (50 000 km)
    I've just noticed a difference between right and left side, the front left side is 2 cm under the right side.
    I've checked the suspension parts after removal of the front left wheel: there's no leaks from the shock, no play in the bushings...
    The car has never been accidented and only a short track experience 3 weeks ago.
    What should I look at now ?
    Many thanks
    Louis
  2. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    where are you measuring the ground clearance from?
    Regards, Jim
  3. louis13
    louis13 Karting
    Aug 28, 2005
    51
    Marseille, France
    Louis
    I've made the measurements from ground to the fender border (?) just above the tire. I've taken the same alignment from side to side by taking the measurement by the center of the wheel. Anyway, you could see the difference just by look at the car...
  4. Dr_ferrari
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    I would suggest checking the ground clearance from the center of the lower control arm bolts to verify.
    regards, jim
  5. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    The proper way to measure ride height would be from the lower edge of the wheel, not tire, to the lower edge of the fender or a set point above the fender lip.
    The bottom of the wheel is a fixed point as is the fender.
    If you try to measure from the ground, while close, you can be off due to tire inconsistencies.
    This will at least allow you to determine whether there is any difference between each side. THEN you can measure ride height knowing where problems may lie.
  6. louis13
    louis13 Karting
    Aug 28, 2005
    51
    Marseille, France
    Louis
    These are the measurements that I got from the lower edge of the wheel to the lower edge of the fender:
    Front Left: 58.5 cm
    Front Right: 60 cm
    Rear Left: 61 cm
    Rear Right: 61 cm
    What would you do next and how to know if the shocks or the springs are implicated ?
    Change both sides (spring and/or shocks) ?
    Louis
  7. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    The ground is not flat or the car is bent or both :(
    My guess is the ground.
    P
  8. louis13
    louis13 Karting
    Aug 28, 2005
    51
    Marseille, France
    Louis
    That's what I was thinking, but the difference is obvious and in different places
  9. suicidedoors1964
    suicidedoors1964 Formula Junior
    Oct 2, 2004
    385
    I would suggest to take it to an alignment shop and let them tell you why. Maybe not as much fun as guessing but certainly better than remote diagnoses over the internet.
  10. Dr_ferrari
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    do not measure from the fender. it can be inconsistant.
    measure from the lower control arm mounting to the ground on a flat surface. my guess is you will find that it is close to even.
    Regards, Jim
  11. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Do you have a concrete garage floor? If not, see if you have a friend with a warehouse or even your preferred mechanic. Those floors are closer to even than a driveway...especially asphalt.
    Shamile
    Freeze....Miami Vice !
  12. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Hahahaha.....! Designed my Michaelangelo....built by Mickey Mouse.... ;)
    Shamile
