GruppeM Intake - More Power? | FerrariChat
Discussion in '360/430' started by JM280z, Aug 13, 2025 at 7:21 AM.
  1. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    894
    Jake
    Hey All,
    I’m considering buying the GruppeM intake. I already have AP Headers, Top Speed Sport Cats, S-Line X-Pipe, and a Mase tune. (Also, the Mase e-diff control module to diagnose/monitor and shut off e-diff to prevent wear)
    I just finished a lot of heat management / upgrading heat shields in the engine bay due to 1) the aftermarket exhaust runs hotter, 2) it’s an old car so to protect mechanics and electronics, 3) to reduce heat to protect carbon fiber from yellowing.
    Now that heat maybe under control better, I may buy carbon fiber engine bay panels and GruppeM intake. I have not seen anyone publish numbers on GruppeM intake before and after but I did see one thread that someone said it maybe create more power exclusively because the upgraded heat shield it comes with and nothing more.
    thoughts?
    https://www.vividracing.com/gruppem-carbon-fiber-ram-air-intake-system-ferrari-f430-0510-p-74336.html
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,974
    Isle of man- uk
    Save your money, the standard air filters are fine.
    ADA///M likes this.
  3. ADA///M
    ADA///M Karting
    56
    Florida
    Adam G
    Would love to see actual dyno results, otherwise I doubt you're gaining much (as with most intakes). Unless you're trying to squeeze out every last couple HP for ultimate track times, I'd guess it's more for looks and maybe sound than anything.
    Mel Spillman likes this.
  4. one4torque
    one4torque F1 Veteran
    5,749
    Houston
    One4torque
    I did not notice any difference, but it looked very nice.
  5. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,790
    Lake Villa IL
    Looks like it would make less power than stock due to the flat face of the inlet. Should be bellmouth.
  6. JM280z
    Aug 22, 2020
    894
    Jake
    Thanks everyone.
  7. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,121
    Josh @jtcarprojects
    Looks cool but until a true before and after I bet the HP is not much or anything
  8. MichaelMatic
    MichaelMatic Karting
    Dec 19, 2020
    169
    Raleigh, NC
    Michael D
    I’m curious if there’s any difference in sound? My old 3RS at low speed had an amazing intake note.
