GT/4 fog light info needed | FerrariChat
Discussion in '308/328' started by srhillgt4, Sep 7, 2007.
  1. srhillgt4
    srhillgt4 Rookie
    Oct 10, 2006
    8
    I've got a US spec. 78 GT/4 that I've owned since "94" and want to retrofit period fog lights. The car is very origanal and I want to keep it correct, if possible. As I understand it, the dealers added these lights and would most probably have used ones purchased in the country were the car was sold. I'm hoping that a fellow forum member can tell me what brand they are or take a photo of the lights from your car. Believe it or not the Ferrari part # is still "good" at $190.00 ea. but basicly unoptanium. I'm guessing they could be Marchall of something similiar based on some of pictures I've seen. If you can help with info, it doesn't matter if it's US, euro, Australian or other, I'll take any info I can get.
    Ciao Scott
  2. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    #2 gerritv, Sep 7, 2007
  3. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
  4. Beta Scorpion
    Beta Scorpion Formula 3
    Jun 22, 2006
    1,379
    #4 Beta Scorpion, Sep 8, 2007
    The parts manual lists the fog lights as "Non vale per USA" and I would probably not add them if you want to keep it original. If you do add them, putting them behind the grill would probably look better than mounted under (or worse, OVER) the bumper.
  5. 3px19
    3px19 Karting
    Aug 29, 2006
    218
    Calvin crouch
    added Carellos to my ,79.
    Found a pair of ebay for $75 like new.
    The mounting bar is already there behind the grill with the hole drilled. easy install.
    On the dash left wing I drill a hole for another warning light and another factory switch. everything looks original
    Cal
  6. srhillgt4
    srhillgt4 Rookie
    Oct 10, 2006
    8
    Hey Guys
    Thanks for all the info, it is much appreciated. Not sure what I'm going to do yet, but at least I know the parts are available if I go that route.
    Thanks again
    Ciao
  7. Gleggy
    Gleggy Formula 3
    Sep 22, 2004
    1,588
    Land of Oz
    Gleggy
    Give John Moretti an email( ex moderator Australian section) he has quite a lot of GT4 parts, he may have what you are looking for.
    Cheers MG
  8. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    The fog/driving lights are brilliant. I use mine all the time. In my part of the forest, it is customary to always drive with lights on, and I don't want those barn doors of popup lights to be up all the time. The antenna switch on my center console has been wired by the previous owner in such a way that flipping it will keep the headlights down (and off) even when switching lights on. So tail lights only then. Flip on the driving lights switch and I can drive around like the customary christmas tree, without the popups.
    Hans
