GT3 RS | Page 151 | FerrariChat
GT3 RS
Discussion in 'Porsche' started by joe sackey, Oct 26, 2013.
  1. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3751 joe sackey, Apr 7, 2015
  2. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3752 joe sackey, Apr 8, 2015
  3. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3753 joe sackey, Apr 8, 2015
  4. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3754 joe sackey, Apr 9, 2015
  5. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3755 joe sackey, Apr 9, 2015
  6. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
  7. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3757 joe sackey, Apr 9, 2015
  8. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3758 joe sackey, Apr 9, 2015
  9. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3759 joe sackey, Apr 9, 2015
    Iconic 2.7 RS Lightweight and contemporary 3.6 RS Lightweight in repose at a chalk quarry somewhere in Wiltshire in the UK.
    The 2.7 RS's Tangerine livery sure looks like today's Lava Orange for the 991 GT3 RS, a nice salute to the past.
  10. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
  11. slm
    slm F1 Rookie
    4,109
    Near Lambeau field
    Steve M
    I have dealt with this dealership. I have one good dealing and one not so good. Get a PPI.
  12. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    As always, that's good advice!
  13. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
  14. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    The Jamiroquai front-man's Porsche Rennsport passion runs deep, as this video shows. Perhaps the RS color palette is the reason he has the world's only Signal Green La Ferrari?
    [ame]http://www.youtube.com/watch?v=PrkqaR8j5uk[/ame]
  15. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3765 joe sackey, Apr 9, 2015
  16. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3766 joe sackey, Apr 9, 2015
    By Josh Barnett - Total 911
    First off, the ‘Mezger engine’ moniker is a bit of a misnomer as legendary engine builder, Hans Mezger has been designing Porsche powerplants since the Sixties. However, in the 911 world, the term has recently become synonymous with the engine fitted to GT3s (up until the introduction of the 991 generation).
    Unlike the M96 and M97 motors with their ‘integrated dry sump system’ (the two-piece crankcase design is, in reality, little more than a modified wet sump), the M96/72 ‘Mezger’ engine utilises a true dry sump thanks to its roots in motorsport.
    The engine was initially designed for the twin-turbocharged 911 GT1 Le Mans racer, meaning that, to reduce oil surge (and a subsequently dangerous drop in pressure) during hard cornering, oil is harvested from the GT1-derived crankcase by two scavenge pumps.
    This oil is transferred to a separate, baffled oil tank (which is mounted to the engine) before oil pumps – one mounted in each cylinder head – pump the lubricating fluid through the various oil galleries.
    The engine is very similar in design to the flat six found in the 962 prototype however, where that powerplant used separate cylinder heads for each cylinder, the M96/72 uses a single head per bank.
    The four-valve head’s design is derived from the water-cooled 959, although extensive work was needed to mate it to the 911 GT3’s cylinder size.
    In the 996 GT3 Mk1 the bore was 100mm, with a stroke of 76.4mm while, by the Mezger unit’s swansong in the 997 GT3 RS 4.0, the bore had been expanded to its maximum of 102.7mm, with the remaining 200cc of capacity increase achieved with an 80.4mm stroke.
    Thanks to its racing intentions, the GT3’s motor doesn’t suffer from IMS bearing failures like its M96 and M97 cousins. While the engine still uses an intermediate shaft to drive the camshafts, the oil pumps are driven directly by the crank. What’s more, the GT1-derived block has a different oil gallery design that ensures the IMS bearing remains lubricated at all times.
  17. Finlander
    Finlander Formula 3
    2,359
    Sunshine State
    Good video…. I'm also a fan of his music.
  18. jamie140
    jamie140 F1 Rookie
    3,298
    GTA/Marco Island, fl
    Jamie
    #3768 jamie140, Apr 10, 2015
  19. jamie140
    jamie140 F1 Rookie
    3,298
    Jamie
    #3769 jamie140, Apr 10, 2015
  20. PbPedis
    PbPedis Formula Junior
    May 6, 2007
    710
    Ontario, Canada
    Dennis
    You're a crazy mofo Jamie. I think that was the one I was close to buying about 3 years ago. It was dirt cheap back then!
    Congrats!
  21. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Fantastic, good move, congratulations, and thanks for sharing!
  22. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3772 joe sackey, Apr 11, 2015
  23. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3773 joe sackey, Apr 11, 2015
  24. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3774 joe sackey, Apr 11, 2015
  25. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3775 joe sackey, Apr 11, 2015
