gt4 coolant removal question | FerrariChat
Discussion in '308/328' started by sltillim, May 16, 2010.
  1. sltillim
    sltillim Formula 3 Silver Subscribed
    Nov 22, 2009
    1,702
    San Diego
    I am changing the belts on the gt4. I am following the instructions on Birdman's website that are thorough. It explains there is a petcock to drain the coolant tube under the front bank on the car. This is a '75 that might predate the petcock because I cannot find it.
    The only way i can see removal of the coolant is to disconnect the small hose before the coolant tubes turn into the frame to the front of the car. My only issue with this is that the coolant tubes sit right over the gas tubes ( the small rubber section - see pics). There is a flashing over this but I assume it is very bad to get coolant on these tubes.
    Should I proceed with disconnecting this section to drain the coolant? If so does anybody have any tips?
    Thank you!
    Spencer
  2. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    Sometimes the pet cock is on the other side of the engine. Dumping the coolant at the front of the car is also a good way.
  3. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,038
    I won't give any tips. My last adventures started out with visions of a neat and clean procedure ending up with lots of paper towels. :)
  4. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    I also just removed the hose and poured coolant into a catch bin below. Not the cleanest way, but effective.
  5. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    Why are you dumping water for replacing the belts, it is not necessary?
  6. eurogt4
    eurogt4 Karting
    Apr 15, 2006
    243
    Sacramento, CA
    You can drain most of the coolant by disconnecting the heater hose return fitting on the main coolant pipe from the radiator. The fitting is under the front, between the front wheels
  7. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    It is necessary to spill holy green water, because the metal coolant pipe blocks the removal of the timing cover.
  8. sltillim
    Nov 22, 2009
    1,702
    San Diego
    I might as well have flushed it anyway because it was just sitting in there for a couple of years. Out with the old and in with the new.
    I used the bleeder in the front. Then removed the excess with the shop vac! it sucked it right out! - remove the filter!!!
  9. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    The petcock is just below the exhaust manifold on the REAR of the engine. You can get at it through the wheel well.
  10. jimshadow
    jimshadow F1 Veteran Lifetime Rossa Owner
    Feb 19, 2006
    6,252
    Indiana/North Carolina
    JIM
    My car doesn't have the petcock either. Follow EuroGT4's advice. That is how I change my coolant. You'll get most of it out.
    Good luck!
    JIM
  11. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    I presume you mean on bank 5-8?, I find it is just as easy to use a stud remover to take out the 1 long stud that prevents you taking off the belt cover fully.
    2 mins effort and no green water all over the place....
  12. robertgarven
    robertgarven F1 Veteran Owner
    Feb 24, 2002
    5,312
    Ventura, California
    Robert Garven
    I am working on a writeup on this but not finished. here are some pics.
    1 you need a funnel and hose and container
    2. Drain from engine petcock, when water stops undo bleeder in front and coolant cap lots more will come out
    3 shut petcock
    4 go to front remove under cover
    5 get large container put under there pull off heater hose , when you do this coolant will come out in two directions I ended up putting a petcock on the pipe there but you can hold the pipe hole with your gloved thumb or rig up a piece of pipe with a plug in it pull of the hose slip the plugged hose on or cover with thumb
    6 wear glasses and shut mouth lots will come out after 10 times you may learn how to do this without making a mess, but its hard to do.... recycle coolant as its very poisonous! keep animals away it taste sweet..........
    have you seen my other chapters??
    http://ferrarichat.com/forum/showthread.php?t=61449&highlight=ferrari+dummies
    http://ferrarichat.com/forum/showthread.php?p=136004973#post136004973
    http://ferrarichat.com/forum/showthread.php?t=120201
    get new hoses from dave helms
    get new clamps
    clean all nipples with scotchbrite
    put a thin coat of silicone paste on pipe
    oh yes go by one of those miracle sponge mop things this is the best advice
