GT4 front boot liner or cover | FerrariChat
Discussion in '308/328' started by KeithS, Sep 1, 2017.
  1. KeithS
    KeithS Karting
    154
    Paradise Valley, AZ
    Keith Stephens
    #1 KeithS, Sep 1, 2017
    The plastic liner has split in several places along the edge. I highlighted one but there are several. I see many GT4's without this liner so I suspect the part is not available. I would like to repair mine. First thought was to reinforce the back side with fiberglass but I fear it would not bond to the plastic. Looking for any repair suggestion.
    Keith
  2. absostone
    absostone F1 World Champ
    10,070
    I think superformance or Ferrari spares has it
  3. absostone
    10,070
    or glue it together with cyano acrolate. crazy glue
  4. Patrick Dixon
    Patrick Dixon Formula 3
    Mar 27, 2012
    1,134
    Almost all are also missing the circular cover over the brake fluid reservoir. Mine used to have one, but it disappeared about 25 years ago when the car was stripped and repainted. Anyone know where you can buy a replacement?
  5. antoninosavoca
    antoninosavoca Formula Junior
    Aug 9, 2011
    283
    Montesilvano Italy
    antonino savoca
    I think you could repair it with fiberglass and a little aluminium piece reinforce
  6. absostone
    10,070
    #6 absostone, Sep 10, 2017
    no the fiberglass will not bond use crazy glue, which is cyanoacrylate. find one specific for plastic. I use it daily in my line of work. just used it today on the arm rest section of my gt4 its the only way to repair it. some of the cyanoacrylates come in different viscosities. line up the repair area and put tape across the repair. than lift the tape on one side only. wear gloves , open the adhesive. make a thin line of glue on the edge of the break, line up and press together . quickly hold with thumb and index finger for a few seconds, .
    then without letting go attach the loose end of the tape to hold the two sides together. better yet I would do it with the liner in place. just put some tape under the crack so he adhesive doesn't drip through.. be careful with your skin and eyes with this stuff. I assume no responsibility . I use this stuff daily in marble restoration. good luck
    sltillim likes this.
