GT4 front header - can it be removed w/o pulling engine? | FerrariChat
Discussion in '308/328' started by sammyb, Nov 3, 2009.
  1. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    Still finding time to work on the '76 308 GT4 (the infamous craigslist car). Welded the rear header, but it sounds like the front might have a bad leak too.
    Has anyone had success pulling a GT4 front header (the one to the front of the car) with the engine still in the car ? Any tips or tricks would be very much appreciated. I'd guess that it would have to be done all from underneath. (I have the car at home now -- if it was back at the shop, I'd simply throw it on the lift and check.)
    Cheers,
    Sam
  2. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    #2 gerritv, Nov 3, 2009
    Hi
    The good news: Removal of engine is not required. You will however have to remove the RH fuel tank and water pipe. I don't recall if I removed the alternator or not. Expect to do a lot of wiggling to get the header out of its spot once unbolted. I did mine on axle stands, my neck muscles are now much stronger as a result!
    Some of the work can be done from above, get a 13mm S or C shaped wrench. And some long extensions for the socket when working from underneath. My car is Euro so the header sheid came off with 4 bolts. If it is the US encased one, then access is tighter. First time took me 5 hours, fourth time I was down to 2 hours :-( After several attempts to repair, it would just start leaking somewhere else. The solution was a stainless header from Superformance.co.uk. Fit was perfect (for my 1976 Euro).
    Gerrit
    http://dino308gt4.com
