Gt4 jacking points | FerrariChat
Gt4 jacking points
Discussion in '308/328' started by Mark van adrichem, May 30, 2011.
  1. Mark van adrichem
    Mar 30, 2009
    139
    6,500 rpm
    Anyone know where it’s best to lift my '79 gt4, front and back?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,666
    South East
    Jimmie
    #2 greyboxer, May 30, 2011
  3. David Jarrett
    David Jarrett Karting
    Sep 21, 2006
    240
    Chatham Kent
    David Jarrett
  4. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Give him credit for removing the sarcasm.
  5. FiatRN
    FiatRN Formula Junior
    Nov 21, 2008
    319
    Denver, CO
    Jonathan Drout
    Mark
    I recently did some service work to my car, and modified my personal procedure. Here's my "latest" idea, which worked very well:
    Use the stock side jacking point and lift the car up about 5 inches.
    Slide 2 peices of 2x12 under the rear wheel - each one about 24" long.
    Lower the car back onto the 2x12
    Now remove your jack from the side, and jack from the back
    You may use the center frame rail that's further forward - NOT the one right at the rear. The one right at the rear is very close to the rear anti-roll bar, and if you use that frame rail you could bend the rear anti roll bar.
    Place your jack stands somewhere very safe - that frame rail works well, and there are a couple of non-transverse frame tubes that work.
    Do NOT get under the car with the wheels only on the 2x12s. It is NOT safe, as the car could roll off and squash you like a bug.
    For lifting the front, you can use the 2x12 tick with the front wheels, but you must show some cleverness about placing the jack and jack stands, bc there are more items to accidentally crush/bend up front.
    Best luck.
    Jonathan
    Denver, CO
    the FiatRN
    GT4 15302
  6. Mark van adrichem
    Mar 30, 2009
    139
    6,500 rpm
    Dear Jonathan, thanks for the tips and effort, much appreciated.
