GT4 on 16 inch: ruined my front fender!! | FerrariChat
Discussion in '308/328' started by Hans, May 24, 2007.
  1. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Hi guys,
    I've got my GT4 on 16" wheels for one day now (205/55/16 front and 225/50/16 rear, on Bridgestone potenza's) and I've driven them for about 150 miles over motorway, country roads and city traffic. I like the firmer ride of the 16 inches when compared to the 15 inch wheels they replace (although the difference is not as pronounced as I thought it would be).
    However, the front wheels have started to rub in the wheel wells. They never did that on the previous wheels (205/60/15). Not only do they rub on the inside of the wells (against the flat panels at the front), but also has the ridge (the metal that is folded inward) at the very top of the wheel well been pushed outward, folding it in the process and ripping the paint and primer off
    I'm not amused...
    I've pushed it back and it looks okay now. I can probably patch up the paint somewhat. I however do not dare to take another curve for fear of a repeat action...
    Has anyone ever had the same happening?
    The rear wheels also rub on humps, but since these are not steering, nothing is being pushed outward. So no big deal. They've always done that.
    On the positive side: The car DOES look wicked with these new wheels....
    Hans
  2. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Hi Hans,
    I have 16" 328 rims on my Euro GT4 with the same tires (need to check to be sure of sizes but they sound the same). I get no rubbing at all, even on the track. I used to get rubbing with my 14" original rims on RH front against the aluminum panel in front of wheel well but that is also gone.
    What type of rims do you have? Is the offset correct?
    Gerrit
    http://dino308gt4.com
  3. thecarreaper
    thecarreaper F1 World Champ
    18,073
    Savannah
    i think you need new shocks. i had a gt4 with 16s and i drove the hell out of it. i never had any issues. i do know the previous owner had redone the shocks and bushing.
    sorry to read of your troubles.
  4. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Lets think about this. If the offsets are the same and the OD of the tire is the same then you won't get any rubbing on the fender. So 1 of those things is wrong. If these are aftermarket wheels then I would check the offset and make sure that it is correct.
  5. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    I'll check the offset. Sounds like the front wheels are placed at a somewhat wider track than the original ones. Hence the rubbing.
    I've got the wheels from www.superformance.co.uk
    I'll measure the offset. Good point (not that it would do me any good to know, come to think of it)
  6. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    That was my first thought...
  7. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Hmmm, the car just had its annual check done, during which the shocks were tested. I'll have a look. THanks
  8. BigTex
    79,386
    Houston, Texas
    Bubba
    When our 360 brothers go with larger wheel packages it's pretty common to have a Body Shop "roll" the fender, compressing the original inner lip from being flat to hugging the outer fender...
    Not too sure of the actual tools/process, but that seems to work, I run 16"s on one of my cars but am careful in tire size selection......no idea what offset.
    Hope your repair goes well!
  9. rtking
    rtking Formula Junior
    Mar 5, 2006
    703
    Huntington Beach, CA
    Bob King
    Your tire size is less than 1% larger than the stock 15" size, so technically you should be OK. But I've also learned that some tires are "larger" for their given size than others. BF Goodrich tires, for example, tend to be wider than a Goodyear from my experience with Mustangs.
    But barring the tire width anomolies, I'd say you'd need to look for a narrower rim. The offset won't help you since you're rubbing the inner fender liner as well as the outside fender. If anything, I'd look to go with either a different brand of tire or go with a smaller tire up front.
    Bob
  10. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Hi Hans,
    Did you get the Mondial rims or the 308 rims? There is a difference. I also assume that the 8" ones are on the rear? (Had to ask, you never know :))
    Can you take some photos of the rims installed, esp. how they relate to the wheel wells.
    Gerrit
  11. jeanlucco
    jeanlucco Rookie
    Sep 22, 2006
    24
    Denmark
    Jean-Luc
    Hi Hans, just received and install a complete 16" set from Superformance with Goodyear on my 77 GT4, went for a long drive last weekend and few laps on a small circuit built inside harbor facilities. Absolutely no problems, big improvement compare to my old 14" Cromodora. Hope that you will found out.
  12. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    You need to get your aligned by someone who knows what they are doing. The Netherlands is a good place to find someone who knows how to align cars.
    For example: the front suspension adjusts for camber caster toe and WHEELBASE. So does the rear.
    My car is correctly aligned and corner weighted with that tire/wheel combo, and no issues.
    jay
  13. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #13 2NA, May 24, 2007
    This is the tool.
    Here's a link to Eastwood:
    http://www.eastwoodco.com/jump.jsp?itemID=6159&itemType=PRODUCT&path=1%2C2%2C503%2C504%2C514&KickerID=323&KICKER
  14. Jay GT4
    Jay GT4 F1 Rookie
    Oct 16, 2001
    4,995
    La mamma dei fessi
    e sempre incinta
    My GT4 has MOMO 16" and rubs like crazy! The car looks great though because it is sitting so low. The cause of my rubbing is soft springs. I'm ordering a set of aftermarket springs and will try them out shortly. I'll keep everyone posted as to how they work. Fraction of the price from Ferrari. They are 1/2" lower then stock and a little firmer.
  15. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,328
    Palos Verdes
    Vince V
  16. Nickt
    Nickt Formula 3
    Feb 24, 2006
    1,741
    Iver, Buckinghamshir
    Nick T
    I have 18" rims on my GT4 and suffered the same issue. I fixed it by replacing the bushes on the fron suspension. I know my front /rear track is wider than OEM and having the rear arches rolled to accomodate the extra rubber. M<y front wheels only rub now on full lock and the rears on a bump at speed.
  17. SonomaRik
    SonomaRik F1 Veteran
  18. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Your springs are probably saggy. The shocks are probably worn out too, but that is not the issue. If the car looks low and mean, they springs are saggy. They did not look low and mean from the factory...they looked like 4x4's!
    Birdman
  19. Mr. Nice Guy
    Mr. Nice Guy Formula Junior
    Apr 11, 2007
    301
    Southern NH
    Eric
    Sounds like he needs some paperweights!
  20. Ron S
    Ron S Karting
    Nov 20, 2006
    159
    Raleigh NC
    Ron Scarboro
    There is only 0.2in difference in the tire diameter and no difference in the width of the tire (other than small manufacturer and profile variances).
    My guess is that the offset is different on the wheels which brings them into contact with fender.
  21. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Or new springs... or both...
  22. Zertec
    Zertec Formula 3
    Oct 5, 2004
    1,335
    Singapore
    Clive Reed
    Is that because the Netherlands are flat?
    :D
  23. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Okay, this REALLY is starting to be a problem now.
    I've had this happening 3 times in 2 days now. When going over some bump with the steering wheel ever so slightly to the left, the top of the lefthand tire hit the fender and pull the lip out.
    (Funny thing is that it is only my left fender. May be my 210lbs sitting on that side of the car....)
    Folding the edge inward might indeed help.
    I'm thinking of upgrading my springs to 25% stiffer ones from Superformance. Yes Birdman, the car looks low and mean, so I am probably sagging.
    I've tried to make some photos of it, but none are clear at all.
    Anyone have experience with replacing the springs? Rather than having the shop do it, I'd like to do this one myself... Two bolts and the whole thing can be taken out, right? Then two spring clamps to hold the spring down, and then???
    Oh, and the wheels have JUST been aligned (like 200 miles ago).
  24. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    P.S. And yes, I'm sure the offset of the wheels is more than on my previous ones, heavily contributing to the problem. Plus the new tires are less ballooning than the previous ones (15")
  25. Nickt
    Nickt Formula 3
    Feb 24, 2006
    1,741
    Nick T
    Hans
    I'm telling you, its a shocker problem.
    I had EXACTLY the same until I replaced my shocks and bushes. I would also suspect you are running a 20mm offset rather than a 25 or 30
