GT4 Timing belt cover | FerrariChat
Discussion in 'Technical Q&A' started by yelcab, Nov 23, 2003.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    I am trying to remove a timing belt cover on the 1-4 (rear) bank. And it is not coming out. THe bolts are out, I can't maneuver it over the belt, the tensioner, and the pulley. GT4 owners that have done this with the engine inside the car, what is your trick?
  2. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Make sure the studs are out, not just the bolts. There are short and long ones, so I just mark (short, long, or none) right on the cover with a Sharpie, and clean it later.
    Basically I just rotate the cover counter-clockwise, and wiggle and angle, and actually at one point have to push the belt away from the boss that is on the inside of the cover. I rotate it almost 180, so it doesnt matter too much which way you rotate, but one way is easier. You will sort of roll it off towards the back of the car, with the last part, the open bottom, clearing the rearmost pulley as the final bit.
    Once you get it, you can't believe how easy it was. Its one of those things. Fortunately, it is even easier for me to put back on. Just resist the temptation to twist the belt out of the way. Just deflect it the 1/4 inch or so straight towards the block.
    Good luck, it is actually pretty easy.
    jay
  3. yelcab
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    Jay
    THey rear bank has no studs, just 3 4-inch long bolts, and they are out. THere are some studs where the timing tensioner is mounted to and they can't come out.
    This is the first step to getting access to the belt so the cover has to come out first. What you are saying is ... remove the bolts, rotate the cover 180 degrees counter clock wise, push the belt back toward the engine as far as it will go, roll the cover (now upside down) back over the engine and it comes off.
    Right?
  4. tbakowsky
    Sep 18, 2002
    20,034
    The Cold North
    Tom
    Did you undo the dipstick tube from the top of the cover?
  5. yelcab
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    No need to, I am working on the other one. The rear bank is 1-4, the front bank toward the driver is 5-8. That is the easy one.
    The rear timing belt cover has much less clearance to the frame.
  6. DEMETRE GOUDAS
    Nov 10, 2003
    13
    Originaly the rear cover has 3 long studs supporting it to the block. Some replace them with long bolts to make future acces better. If that is the case with yours then it is only a matter of finding the proper route out .Just take your time and use your head . AVOID PRYING ON ANYTHING.
  7. yelcab
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    My spare parts catalogue shows the 3 long bolts as original. I will try again to rotate the cover 180 degrees. THere must a way out. Can't remove the engine just to remove the cover.
    The last time I did the belts, the engine was out for a rebuild.
  8. tbakowsky
    Sep 18, 2002
    20,034
    The Cold North
    Tom
    D'oh!! Don't I feel like an idiot..should have read your post slower!!
    The cover will come out with some fiddeling. You have to hold your tougne the right way and make sure you have excalty 52cents in your left pants pocket and then it will come out.
