GTB QV 49461 refurb | Page 10 | FerrariChat
GTB QV 49461 refurb
Discussion in '308/328' started by viper_driver, Oct 26, 2009.
  1. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,589
    Honolulu
    Kevin
    How does this sound?
    Put the whole assembly in the oven at 200 degrees for 15 minutes and then apply some cold to the injector to shrink it a little. Remember to have the hot pot holder gloves ready for removal from the oven. Also this wil most likely upset the person who uses the oven because the caustic smells from the process will linger in the oven so you may need to clean it afterwards. Use caution to not freeze the cast aluminum part, only the steel? injectors. If this is non-sense someone please speak up because thats how I would approach this problem, after the continued soaking of penetrants failed. Admittedly I am not familiar with the assembly so my suggestion may not make sense for reasons unknown to me.
    http://www.loctitefreezeandrelease.com/
  2. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,339
    Encino, Ca
    Carl T
    Are you using a flare wrench, like you would on a brake line, on the 14mm fuel line?
  3. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    Yes, a flare wrench. That's what is actually opening enough to go around the 14mm line. Crazy, but I'm putting a lot of pressure on it. Maybe a snap on version wouldn't do that.
  4. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #229 viper_driver, Dec 2, 2010
    Check out the old one, I don't think it was going to last much longer. Luckily I found this before it broke, would have been kind of a problem if it happened while driving around.
    It's easy to reinstall, there are two hard lines that contain the cable. One curves around behind the motor, then there's open space under the car, then another hard line about even with the middle of the seat that carries it up to the pedal.
  5. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    Why have I never seen this thread? Anyway I like what you did with the bumpers. Did you have any holes in the front from people installing various license plates?
    What did you use as a filler?
  6. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #231 viper_driver, Dec 2, 2010
    nope, no bumper holes luckily.
    Last project for the winter is the shifter. I finally figured out that the play and clunk in my shifter was the shift box itself, not the transmission. If I held pressure up or down on the shift rod with my hand while shifting, it was perfectly smooth.
    Today I removed the whole assembly. Here's a pic of the problem, you can see the oblong hole in the last pic. The case bottom has been worn about .065" over time. When the lever is moved fore or aft, the shaft hits against the top and bottom of the case halves.
    Not totally sure how I'm going to fix this, I'll be making some sort of sleeve I think to get it tight again. I suppose I could just weld some more metal on it and start over again.
  7. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #232 viper_driver, Dec 6, 2010
    I finally got it, managed to only ruin one of them. Based on how rusted the threads were, I'm happy with that.
    In order to get them loose, I pushed the injectors out of the manifold with the lines still attached. Then I filled a glass full of PB Blaster and dunked the ends of the lines and injectors into the glass. I let that sit for a couple days soaking in the Blaster. Then I put the injectors in a vise, sprayed the injector with some kind of freeze rust spray junk, and put the longest lever I could on a closed end 14mm wrench. Two of them broke loose easy and were fine. One was pretty bad and got the threads messed up, but I managed to fix it with my homemade tap. The last one was the worst and the fuel line nut actually broke in half as I was trying to turn it.
    My camera isn't the best, but here's a pic. Now I just need to figure out how to get this one line replaced and I can get it back together with fresh injectors.
    Thanks for the help guys.
  8. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #233 viper_driver, Dec 27, 2010
    Slow going trying to fix the fuel line.... I think Verrel is coming through with an 'unobtanium' part.
    This week I'm planning to repair the shifter case, fix the mangled fuel line, and sandblast the manifolds. No amount of chemicals can get them clean.
    I got some new graphics for Christmas. New paint sticker modified to have my correct paint code. Windshield sticker. it's hard to see from the pic since it's still on the backing, I'll take another shot when it's on the glass.
    Finally, my son's new Tonka, the best Christmas present ever.
  9. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #234 viper_driver, Dec 27, 2010
    Repaired the shifter today. I milled .058 inches from the top of the bottom half of one end of the case to take up the slop at the rear hole. I figure I can do this about 3 more times before I have to think of a new fix....should be good for a hundred years or so.
    Moves perfectly smooth now. If anyone is looking for a way to spend an afternoon with some preventative 308 maintenance, get access to your shifter through the console and put some grease on the back end of the case. Mine was working metal on metal for quite a while and some grease every few years would have stopped it.
    Also pictured is my sandblased injector manifold. It's the only way I could get the grime off.
  10. tempest411
    tempest411 Formula Junior
    Dec 3, 2010
    564
    Wow, I've been reading this thread on and off as I could all day today. You do great work! By, my gosh, how do you find the time?! I'm jealous...
    Rick
  11. sdsdesilva
    sdsdesilva Rookie
    Apr 10, 2005
    39
    Cambridge UK
    sdsdesilva
    Where did you buy the windshield sticker
  12. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    this guy:
    [email protected]
    He's the same graphic designer that made my window sales sticker.
  13. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    Thanks Rick, I work for the government so I guess that's where the free time comes from. Nobody working for the government is working too hard.
    I kid, I kid.
  14. tempest411
    Dec 3, 2010
    564
    I know what you mean; I work for a subcontractor to the government. But my stuff can't be brought in to the place:(
    Rick
  15. sdsdesilva
    sdsdesilva Rookie
    Apr 10, 2005
    39
    Cambridge UK
    sdsdesilva
    Thanks for that info
  16. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #241 viper_driver, Dec 29, 2010
    My custom fuel part showed up today from Verrel. I had it installed about 10 minutes later. I think I can finally get the car back together now and back on the road.
    Heated the old end up with acetylene, removed the tip, installed the new (uncracked) nut. Then, some silver solder and the new tip is on ready to go. Really simple actually...assuming it doesn't leak or break off.
    Thanks Verrel!
  17. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #242 viper_driver, Jan 8, 2011
  18. 4re308
    4re308 F1 Rookie
    4,897
    Woodstock, GA
    Mitch D
    Wow Jason, amazing thread. I'm impressed with your skills and "go for it" attitude. You would do well running a restoration shop. Love your car!
  19. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    No kidding. Seriously cool stuff going on. What an inspiration!
  20. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    It runs! Started it again for the first time in couple months.
    After all the stuff I've messed with I was half expecting it wouldn't start. Took a while cranking to get fuel back into all the lines, but it works again. Can't wait to get the coolant flushed and start driving again.
  21. Nurburgringer
    Nurburgringer F1 World Champ
    Jan 3, 2009
    11,187
    Texass
    congrats!
    Awesome work, enjoy!
  22. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    I have a question for you. What size rivet did you use on the 2 louvered plates that mount underneath the rear bumper/1/4 panel? Mine need a refinishing as well.
  23. fiatbrett
    fiatbrett Karting
    Aug 20, 2009
    98
    Tallahassee, Florida
    Brett B
    I re-finished mine recently and I believe the rivet size for the rear louvers behind the wheels was 1/8".
  24. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    #249 stevel48, Jan 13, 2011
    Thanks!
    It's one more item on my winter projects list.
    All new injectors
    fuel line clips
    new wires
    distributor seals
    refinished intake and TB
    new fuel, air and coolant hoses
    fuel filter
    Brakes in the spring
  25. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
