GTC A/C blower motor | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, Aug 1, 2020.
  1. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    I have a clients GTC we are restoring. As we are assembling the car, all components are restored and run before installation - which leaves me to the AC evaporator box in the car.
    Bench testing it after we disassembled it and reassembly - i believe the blower motor has a vibration at high speed that i cannot get rid of. With the vibration obviously more noisy than what i expect, so in the car, i pretty sure i would not like it.
    Taking it apart 4-5 times trying to isolate the vibration - im considering to replace the DC blower motor - it has 2 shafts on both ends and the only number on the motor is 5577 FH 12V 235
    It measure 2 15/16 diameter, motor housing 3 1/4 and end to end with shafts is 8 inches.
    Any thoughts on what and where to get this. I searched all over but not having any idea on the speed of the motor etc, im running into WTF.
    Any thoughts - anyone replace one of these?
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,929
    romano schwabel
    you may try to let the motor run alone. if then no vibration you may balance the airfan
  3. Bob Zambelli
    Bob Zambelli F1 Rookie
    Nov 3, 2003
    3,497
    Manning, SC
    Robert G. Zambelli
    Contact Steve Cantera - I believe he used a Mercedes fan motor.
    Bob Z.
  4. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    feels smooth with the fans off and on.....however there is a flutter noise at start up and slow down - that i think is coming from the motor itself.
    I thought the fan shrouds were causing some oscillation but with everything apart - im leaning toward the motor.
    yes each squirrel cage fan has a small clip to balance it - they are in their orig positions and it seems to be ok....
  5. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    OK bob - will check it out
  6. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    SPAL USA still sells these quite reasonably, around $200 depending on sizing
    Their website gives you several options but I admit not seeing your system or sizing it
    One thought, perhaps even cannibalize some of the new pieces and graft onto old OEM to keep the maximum number of original parts?
    I'm producing a supply fan system for the Dino A/C system to boost A/C cooling airflow and I can confirm that SPAL USA does have inventory
    https://www.spalusa.com/products/blowers/dual_wheel/
  7. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    thanks for the lead - yes they look similar for sure - will need to get some specs on the size etc to see what could work.
    I did order a motor only yesterday in an effort to address the issue, it seems to be a good replacement. I will know later in the week and if it works, ill post some info on the type and style etc. I can see that the SPAL units, the molded duck work might mount slightly different, thus modifications to the existing evap box, but that is not a big deal.
    My big issue, is the loud harmonics on high speed that i believe is coming from the motor when all assembled. I really dont want to install this without resolving this issue as doing it later (dash and interior all out of the car now) will be a hugh problem.
    Their prices are very reasonable @ 130.00 for a whole unit, motor, cages and housings. I have heard from RPM in vermont where they were making these AC units complete that they are using motors with varying resistance in them to eliminate the resistor rotor switch and just using a 4 position switch which is more available. Sounds like a good improvement etc.
  8. SCantera
    SCantera F1 Veteran
    5,173
    Living Falls NC
    The shop that does my work in Naples swapped out the blower motor with a 1997 MB E-Class motor. The tech said it was "plug and play".....but I did not see the install personally. The MB motor seems to push a lot more air than the original motor. For a really hot day if you direct all 3 vents to the driver it will cool you off fairly quickly. And if you are on the highway it will keep both occupants cool. Around town not so much on a 90+ degree sunny day. But I also replaced the York with a Sanden compressor, installed a GMAC larger condensing unit that's the same width of the radiator, and swapped out the 3 blade Lucas fans with 8 blade Spal fans and shrouds to push more air through. Of course these are not original but the system works better than stock. I kept all of the original parts. I don't take the 330 to shows to be judged. It's my favorite driver!
    christc likes this.
  9. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    thank you steve for the info - sounds like all great upgrades to the system to maximize the AC.
    I will investigate the MB motor to understand its design and style.
  10. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    Found a Mack Truck blower motor with dual shafts and about 1/8 difference on the diameter of the motor housing. So a little rubber insulator around the motor housing to mount it did the trick. The oscillation seems to happen when the load of the air flow would occur - thus my decision to replace the motor. This DID fix the problem and now the unit runs smooth with out vibration/oscillation.
    With the new 3 speed switch and the rheostat replaced - (also mack tuck parts) im ready to reinstall the AC box. Ill get the numbers of the parts i used for replacement for future reference here on the site - in case :)
  11. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    JimEakin and SCantera like this.
  12. JimEakin
    JimEakin Formula Junior
    Jun 13, 2015
    988
    Mountain Living
    Jim
    I’m having significant overheating problems with my 330 GTC when I’m going slow on a hot day. (No issues when going 30+ mph.). The stock fans are not pushing air. With no shrouds, I don’t see how the fans work at all.
    SCantera, I sent a PM.
    Hope I can get info about what others have done to fix this. I’m even thinking there needs to be a fan on the other side of the radiator to pull air out through the side vent.
    I saw a picture of the air cleaner on a 365 2+2 that routed the intake ports to a cold air box. Anyone tried this on a 330?
  13. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    Well, here are some thoughts......
    1. Condition of the radiator?
    2. Voltage on the fan or fans....does it have AC (means u will have two fans) ?
    3. Fans turning in the correct direction - to push the air vs pull (lucas motors go both ways) ?
    4. Is the fan relay turning on based on the rad temp switch?
    5. Solid grounds on all the parts of the cooling system?
    6. Rad temp switch on bottom rad working etc?
    Bit of a process of elimination....but all critical on the cooling process
  14. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    the radiator seems to be ok and not blocked because when you go a little faster it cools down.
    so check the temperatur switch for the fans and the fans also
    may be that the waterpump is not working right anymore and so less water circulation, but this I not think happened
  15. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    good point on the water pump......
  16. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    The car does have AC so 2 fans. Will check air flow direction. Fans seem to come on at correct temperature.
    Not sure of radiator condition. Next up is draining and refilling. A friend recommended using a radiator flush cleaner. Is this safe?
    It just seems that at low speed the hot air is not being removed from engine compartment. Not just high water temp, but possible vapor lock in carbs.
  17. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    Run the electric fuel pump to get rid of vapor lock.
