GTC Build Sheet - to share info from | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, Aug 7, 2018.
  1. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    Anyone have a GTC build sheet they can share with me that is around serial number 10061?
    I am interested in some of the detail parts used at this build time as we are restoring this GTC.
    Appreciate any consideration to this.
  2. 10speed
    10speed Rookie
    Sep 18, 2013
    18
    There is a 330 GTC/GTS As Built Configuration and Judging manual on the FCA National web site. There are build sheets in that manual. Go to the Community TAB, then the IAC/PFA TAB to find the manual. The manual will also help you with your restoration process.
  3. amerikalei
    amerikalei Karting
    May 23, 2011
    196
    Very interesting, clearly a labor of love. Wish there were similar manuals for the 250 GT Pininfarina and GTE models.
  4. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    10speed, thank you for the info -
    yes I'm familiar with the As-Built configuration book by Clete - an amazing and well done guide. There are one or two build sheets in the book as well.
    what I'm attempting to find is one around the same serial number of my clients car - so that i can be more certain
    of the correct parts are used. With the evolution of the GTC during production, tying the parts to the build /vin number
    will help me get it correct.
    One F-chatter has provided me a build sheet from one of his cars, but it is late 105xx - good reference but a little on the late side.
    Thanks again.....Eddie
  5. maserich
    maserich Karting
    Mar 13, 2008
    169
    I am trying to identify a trans, driveshaft, and rear axle assy..
    can you give me the driveshaft length please?
  6. Bob Zambelli
    Bob Zambelli F1 Rookie
    Nov 3, 2003
    3,492
    Manning, SC
    Robert G. Zambelli
  7. maserich
    maserich Karting
    Mar 13, 2008
    169
    Oh..Sorry
    That question was about a 330 GTC restoration.
    I have a trans, driveshaft and rear axle assy from some sort of 330GT(?) and thought the driveshaft could identify if came from a GT or GTC,S.
  8. TTR
    TTR F1 Veteran
    5,137
    Riverside, CA
    Timo
    Likely from GT.
    GTC/-S, if I'm not mistaken, came with transaxles.
    Doesn't your trans & rear axle housings have assembly numbers ?
