GTC Fan Motors | FerrariChat
GTC Fan Motors
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, May 4, 2018.
  1. enio45
    enio45 Formula 3
    1,644
    Gilbert, AZ
    Ed
    Normally i have see the Lucas Fan Motors (bread box type) used on most of the 330 cars.
    My customer sent his car to me in pieces and it has round MM motors - like on a 365 or daytona.
    IT is always possible that the factory could have used these - however has anyone see the round MM
    rad fan motors on a GTC as orig installations?
    Here are the pics of what i have
    The blades i have are correct for the GTC, but not sure of the fan motors.
    I ran this by Clete and he has not seen this either - so maybe asking around i can get
    some clarification if anyone else has seen this on orig cars. This is a later car - serial 10061
  2. 330 Spyder
    330 Spyder Rookie
    Mar 10, 2012
    12
    Nashville, TN area
    330 Spyder
    I believe these were installed as a replacement/upgrade for the original Lucas motors. I used to see cars at times with one of each and all with the correct original blades used. I am fairly certain that Lucas motors are correct well past SN 10061.
  3. johngtc
    johngtc Formula Junior
    Mar 4, 2005
    817
    Yorkshire, UK
    John Gould
    GTC #11333 has Lucas fan motors as well. This was a July 1968 delivery.
  4. enio45
    enio45 Formula 3
    1,644
    Gilbert, AZ
    Ed
    sounds correct guys - that is what i have been hearing and seeing as well.
    ill have to look for the lucas ones for this resto.
  5. 330 Spyder
    330 Spyder Rookie
    Mar 10, 2012
    12
    Nashville, TN area
    330 Spyder
    I believe E-Types have the exact same motors just with different fan blades.
  6. Jumprun
    Jumprun Karting
    Feb 7, 2012
    227
    Southern California
    T. Martinez
    ET
    E Type, same motor but runs in the wrong direction, easily remedied by unsoldering and switching wires inside the housing. Strangely, the Jag housing has a little arrow on the end of the body that would indicate the direction but it runs the other way, so beware that the indicator arrow may be wrong.
  7. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,038
    Jumprun is correct. I have lost count of all the 275's and 330's I have found over the years with the fans running the wrong direction, Have cured a lot of overheating that way.
  8. enio45
    enio45 Formula 3
    1,644
    Gilbert, AZ
    Ed
    So to be correct - so i don't get this wrong....
    Ferrari Fans push air thru the radiator toward the motor - Jags pull air coming thru the radiator from the motor
    Correcto??
  9. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    I think you are right Ed
    that is why I changed the fans from my BB from the front ( blowing ) to the rear sucking and never have problems anymore with overheating. sure I took modern fans
  10. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    Ed, in a Jag E-Type the electric fan/motor is behind the radiator but in the 60's Ferrari's it is (they are) in front of the radiator, so the motors cannot be interchangeable without changing polarity. Doing this in a DC motor is just as easy as swapping the terminals.
    john
    turbo-joe likes this.
  11. enio45
    enio45 Formula 3
    1,644
    Gilbert, AZ
    Ed
  12. 1monza
    1monza Formula Junior
    321
    Manhattan Beach, CA
    Norbert Hofer
    New correct Lucas motors are availible. You can get either the push style for Ferrari or pull style for Jaguar.
  13. enio45
    enio45 Formula 3
    1,644
    Gilbert, AZ
    Ed
    where are they avail at - have not seen any new ones?
