Gtc4lusso Brakes squeak | FerrariChat
Discussion in 'FF/Lusso' started by Emirateshills575, Feb 1, 2023.
  1. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Hello, do you have ceramic brakes squeak too? I though its fixed this on cold brakes.
  2. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    Ceramic brakes are notoriously noisy at creeping speeds.
  3. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    I heard porsche and Mercedes fixed this problem with new coating
  4. dustywusty
    dustywusty Formula Junior
    356
    Florida
    They squeak on my AMG GTR also. Normal.
  5. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    I doubt it. You cant really coat ceramic brakes... Maybe you are talking about the hardened steel brakes on Porsches, which indeed come with a special coating giving them a shiny finish?
  6. VOKS7780
    VOKS7780 Karting
    100
    Los Angeles, CA
    VIC OVASAPYAN
    It's over accumulated break dust that is causing the squeak 99% of the time. Take your wheels off and use compressed air to blow off any break dust residue around the caliper & pads. I've tried this trick with all my cars including Ferraris and it almost works all of the time.
  7. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,459
    Tampa FL
    Wash the brake rotors with car soap and flushing them and the calipers real good with water. This will fix the sequel for a while. It’s the brake dust.
    Also, If you use tire dressing only spray it on your tire dressing sponge, away from the rotors and wipe on tire. Never ever spray tire dressing on the tire and get the dressing on the rotors. Tire dressing and carbon ceramic rotors do not mix well.
