Gtc4lusso check engine error | FerrariChat
Discussion in 'FF/Lusso' started by Emirateshills575, Feb 1, 2023.
  1. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    KennethCDO likes this.
  2. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    It shows "engine control error" and "system not programmed"
  3. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    Well we cant really help with that. You need to go to the dealer. It might be a faulty battery leading to an ECU not booting properly. It could be a bad ECU, it could be a damaged wiring loom... Did you do a PPI?
  4. sid12345678910
    sid12345678910 Karting
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    Try and preform a proxy align with your autel. It basically tells all ecu's to say "hello" to each other.
    Do you know what caused it? What did you do that caused the light. Need more details
  5. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Alredy ordered official software for BCM module update. Let's check
  6. Bamsefar
    Bamsefar Formula Junior
    Nov 26, 2012
    524
    This message is a sync problem between nav unit and well anything. Can be solved by syncing up all ECUs. This message seems to be more frequent after servicing a Ferrari.
  7. sid12345678910
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    Yep, proxy align does exactly that. It's in the nvm body computer special function
  8. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Do you know how long it going?
  9. Bamsefar
    Nov 26, 2012
    524
    Not sure I understand what you are asking for? Syncing take maybe a hour or so.
