GTC4Lusso DCT question | FerrariChat
Discussion in 'Technical Q&A' started by Y812, May 12, 2025.
  1. Y812
    Y812 Rookie
    Nov 16, 2024
    10
    Yuri
    How it is better to use DCT: for example i stopped at the red traffic light or stucked in traffic jam for a long time, will it be better to put gearbox in N or it does not matter and the car can stand in 1st gear with foot on the break? Maybe you can advise something else re how to prolong the life of the gearbox?
  2. windsock
    windsock Formula 3
    1,134
    Requesting Neutral with the paddles does not get you neutral. The only way to get all the shift forks to a neutral position is opening the hood. Almost all the issues we see with the gearbox are electrical or leaks.
    Y812 likes this.
  3. Y812
    Y812 Rookie
    Nov 16, 2024
    10
    Yuri
    Thank you dor the information, so i can drive the car as with regular automatic transmission, keeping it in manual or automatic mode does not make any difference? I'm sorry for stupid questions, but it is my first car with DCT transmission as well as my first Ferrari. Maybe you can share any advise how to minimize the risks for gearbox?
    LittleEnzo likes this.
  4. LittleEnzo
    LittleEnzo Karting
    Nov 10, 2024
    61
    FPS
    really? Is there a good place to read up?
  5. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    762
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    The factory Shell oil ( sponsor ) eats the internal solinoid seals ……with time .
    Eventually the g box will need dropping , opening up and the seals / solinoid s replacement.
    This can now be done .
    At first with power warranties Ferrari just replaced the whole unit . All this did is kick the issue into the long grass , further down the road .
    A good Indy ( whose aware of the DCT killer ) won’t use Shell g box oil . Ferrari main dealers continue to use Shell .
    Y812 and LittleEnzo like this.
  6. Motob
    Motob Formula 3
    Nov 11, 2003
    2,347
    Frederick, Maryland
    Brian Brown
    #6 Motob, May 14, 2025 at 7:28 PM
    Umm, there is no neutral in a Ferrari DCT gearbox ever. The box is always in two gears at the same time. This is how a DCT gearbox works, by releasing the clutch on one gear while applying the clutch on the next. When you are sitting still with the car and the display reads "N" or "P", the transmission is in 1st and reverse gears at the same time. When you select either one of these gears, the appropriate clutch (even or odd) is applied for that gear. Opening the hood makes no difference to the shift fork position.
    Y812 likes this.
  7. LittleEnzo
    LittleEnzo Karting
    Nov 10, 2024
    61
    FPS
    Thank you very much. I should've read up on this. Interesting stuff.
  8. Y812
    Y812 Rookie
    Nov 16, 2024
    10
    Yuri
    Can you suggest which particular gearbox oil is better to use? Thanks
  9. windsock
    windsock Formula 3
    1,134
    Unfortunately, you are incorrect. We rebuild one of these a month or more and all shift forks revert to neutral if the hood switch is open. All shift fork position sensors will read 1200.
    connect your scan tool and confirm it yourself. 1200 is neutral and 400 or 2000 is a gear engaged depending on the direction of the fork. Hood open and car running will result in all the forks going to the 1200 position for safety reasons.
    Caeruleus11 likes this.
  10. Portofino
    Sep 17, 2011
    762
    Portofino
    Except the Shell Ferrari use .
  11. KnifeEdge2k1
    KnifeEdge2k1 Formula Junior
    Jun 1, 2022
    320
    Dominic Leung
    You can select neutral by pulling both paddles
    There's no reason to do this though as DCTs aren't built in the same way that the old SMGs (F1 boxes) which were actually a conventional manual transmission being actuated via electrohydraulic robotics and had a conventional clutch/throwout bearing etc.
    THAT's the reason why it was better to put the car in neutral in the old F1 boxes, leaving it in gear when stopped ammounted to the same thing as keeping a manual car in 1st and holding the clutch open which added wear to the throwout bearing. What you're doing is saving that bearing, not the actual clutch/flywheel pair.
    In an extreme scenario if you are just stopped with the engine running with the clutch depressed (whether it be in an F1 SMG or regular manual transmission) the thing that's wearing is the throwout bearing not the clutch.
    In a DCT the clutches are hydraulically actuated so if there's no hydraulic pressure being sent to the clutch, then nothing is forcing the clutches together. Whether the shift forks actually have a gear selected or not doesn't really matter. The clutches in the DCT won't wear any more or less with you in gear or not and there's no throwout bearing to worry about.
    It's not a bad idea to put the car into neutral in an F1 car when you get to a long stop or any time where you would put the car into neutral if you were driving an MT car. Even if you don't it's not the worse thing in the world either so long as you're not just sitting there for minutes and minutes. Hell... even if you do that the only thing you're hurting is the throwout bearing which isn't exactly a dfficult or expensive part to replace. In many cases it's something you would replace when you do your clutch anyways.
    Y812 likes this.
  12. KnifeEdge2k1
    Jun 1, 2022
    320
    Dominic Leung
    OK nevermind apparently the throwout bearing in the F1 boxes is a ~700 pound part so yeah, put the car in neutral and save it if you can.
  13. Motob
    Motob Formula 3
    Nov 11, 2003
    2,347
    Frederick, Maryland
    Brian Brown
    That's crazy. I have rebuilt 10+ of these gearboxes and never knew that information. It is not in any of the Ferrari factory information that I received at the dealer level or at Ferrari training. How did you discover this? Was someone looking at fork position and had the hood open?
    You learn something new everyday
    Thanks!
  14. Motob
    Motob Formula 3
    Nov 11, 2003
    2,347
    Frederick, Maryland
    Brian Brown
    This is also not true. When you put an F1 car into neutral at a stop, the clutch does not close, saving the throw-out bearing. It stays open. You can confirm this by looking at the clutch under the car through the inspection port at the bottom of the bell-housing. If you let the car sit running in neutral for a long time, I can't remember if it's 10 or 20 minute, then the clutch will finally close.
    flash32 likes this.
  15. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,700
    Central NJ
    Dominick
    Motob you are correct
  16. tazandjan
    39,058
    Affirmative, clutch is always open on an F1 Ferrari when stopped, regardless of what gear she is in, including neutral. Since the clutch is a constant contact type....
  17. KnifeEdge2k1
    Jun 1, 2022
    320
    Dominic Leung
    oh wow i didn't know that
    That seems like such a terrible design
    windsock likes this.
  18. windsock
    windsock Formula 3
    1,134
    It was covered in the factory training I attended.
  19. Y812
    Y812 Rookie
    Nov 16, 2024
    10
    Yuri
    Thanks to everybody for the valuable info. By there way is there any periodic service to be done for DCT gearbox except oil change?
