GTC4Lusso ground clearance ? | FerrariChat
Discussion in 'FF/Lusso' started by Magnus Kanerfalk, Sep 18, 2020.
  1. Magnus Kanerfalk
    Sep 12, 2020
    61
    TioMango
    I have searched but cannot find... What is the ground clearance on the Lusso, normal (lowered) and opt. lift up? Thnx
  2. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,356
    The Netherlands
    FF ground clearance is listed at 145mm but I checked mine and it’s closer to 135mm +/-5mm at the front.
    The user manual for the FF says that the lift adds an extra 40mm.
    I’m aware that the Lusso may be different but I suspect it’s not materially different...
  3. Magnus Kanerfalk
    Sep 12, 2020
    61
    TioMango
    Thanks a lot for your answer, probably about the same on the Lusso
  4. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,558
    Longmeadow, MA
    Eric
    I’ll measure when I have a minute
    Caeruleus11 and Magnus Kanerfalk like this.
  5. Jlee504
    Jlee504 Karting
    Apr 8, 2017
    128
    How necessary is the lifter? Less than half the cars I’ve looked at have it? Trying to determine if it’s a deal breaker.
  6. Magnus Kanerfalk
    Sep 12, 2020
    61
    TioMango
    Well i guess it depends on where you live and how you use it. For me I think it will be absolutely necessary to have it.
    Caeruleus11 likes this.
  7. Caeruleus11
    Caeruleus11 F1 World Champ
    11,610
    I will measure when I get a chance. I don’t use the lifter very often- but the few times I’ve used it, I am surely glad I have it. Everyone is different but speaking entirely for myself, I would put the listen one notch down from “must have” category, it is, however, very much at the top of the “nice to have” category.
  8. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,783
    Weston, MA
    Paul
    Unless you are regularly going to negotiate steep angles between a street and a driveway, you don't need it. I have a neighbor with a fairly steep driveway and I can go up and down his without using my lifter, albeit slowly. This is on a FF, might be different on a Lusso.
    Magnus Kanerfalk likes this.
  9. Jas
    Jas Formula 3
    Mar 2, 2005
    1,060
    Kent, UK
    Jas
    Completely pointless.... until you need it :) In other words, it's a "must have".
    Magnus Kanerfalk and 350MH83 like this.
  10. Caeruleus11
    11,610
    I just did some measurements, please note I am just a regular person!
    Front bumper under center- 6.25” / 158.75mm / {the lower section is a plastic (or CF if you option it) extender and then behind that it the cover sits a little lower than this piece. I measured under this lower area! }
    Rear diffuser under center- 6 ¼” / 158.75mm
    Front wheel arch - the area at the front - 5” / 127mm
    Front wheel arch- the area at the back - 4 ⅞ “ / 123.825mm
    Rear wheel arch - the area at the front - 5 ¾” / 146.05mm
    Rear wheel arch - the area at the back - 6 ¼” / 158.75
    This is with the car at rest on a flat surface (inside my garage). I do have the lifter. I remember reading somewhere that it will lift both the front and rear (the only Ferrari with both front and rear as I recall) by 2 inches which is 50.8mm. I believe Ferrari has the lifter on both ends with Lusso because of the length of the vehicle. One thing to remember with any vehicle with a lifter on one end- when you lift one side, the other side gets lower! (This is a real issue with Pista!!)
  11. Magnus Kanerfalk
    Sep 12, 2020
    61
    TioMango
    thanks a lot, I guess I could manage without the lifter but I think it would be really great to have. Time to start looking for the perfect vehicle!
