GTO and CCM2 2nd Generation Ceramics | FerrariChat
Discussion in '612/599' started by tazandjan, Dec 2, 2010.
  1. tazandjan
    39,174
    Anybody track their GTO and have any information on how well the CCM2 brakes on your car are wearing? Your cars are the first application for the new brakes. The next application is the 458 Challenge. Was wondering if the pads and rotors were lasting longer since Mov'It now has ceramic rotors and pads that last way longer than the original CCMs.
    Taz
    Terry phillips
  2. Tifosi15
    Tifosi15 Formula 3
    Jul 15, 2009
    2,125
    Austin
    Bryan
    I think M made comments about them when he mentioned the Spa Ferrari Racing Days event in his First Impressions thread
  3. tazandjan
    39,174
    Bryan- Thanks, will review. I read the thread originally and do not remember anything about wear.
    Taz
    Terry Phillips
  4. Tifosi15
    Tifosi15 Formula 3
    Jul 15, 2009
    2,125
    Austin
    Bryan
  5. Ferrarista3
    Ferrarista3 F1 Rookie
    Oct 30, 2007
    4,595
    MC/UK
    Carlo
  6. tazandjan
    39,174
    #6 tazandjan, Dec 4, 2010
    Bryan, Carlo- Thanks, just what I was trying to find. My main curiosity is because my car is fitted with Mov'It CER ceramics and they have proven to last much longer than the first generation CCMs on the track. It now appears they probably last longer than the CCM2s, as well, so my outrageous investment is justified, even if I have no intention of tracking my car.
    Incidentally, Pagid also produces the pads for Mov'It, to their proprietary compounds and specifications, and the pads are not available directly from Pagid. So no surprise the CCM2 pads are made by Pagid, as noted in the threads you highlighted.
    Here are some photos of the Mov'Its. Sounds like them making replacement rotors and pads for GTOs and 458 Challenges might be a good idea, too.
    Taz
    Terry Phillips
  7. Ferrari 360 CS
    Ferrari 360 CS F1 Veteran
    Dec 4, 2004
    6,888
    Cape Town,SA
    Jacques
    Interesting, a friend of mine is about to take delivery of a GTO and he drives hard on the road and track, will be interesting to see how the pads wear, though on his 599 the pads lasted 2 years...with hard road and track use included. Having said that though they only lasted 10 000 kms....
    I suspect Ferrari do slightly compromise durability in the quest for outright performance, the same was true of the 575 HGTC where Ferrari admitted the tyres used were less durable in order to create more outright grip.
    BTW: I enjoy reading your posts!
  8. tazandjan
    39,174
    #8 tazandjan, Dec 4, 2010
    Jacques- Here are some more details on the Mov'It brakes and their toughness. The difference between CERS and CCM is the CERs are solid carbon silicon carbide and the CCMs have a carbon silicon carbide core with a braking medium bonded to the core. I was hoping the CCM2s might have the same solid rotor surface, but it now appears they do not. The CERs generate at least as good braking force as the CCMs and are unaffected by heating cycles. Here are the details from someone who has been running them on a Porsche and note there was no measurable CER rotor wear during testing. Not the case with the CCMs or CCM2 rotors based on those GTO photos.
    The HGTC was fitted with Pirelli Corsa tires, a DOT legal competition tire similar to Michelin Sport Cups. As you know, the HGTC also had large CCM brakes, 398 mm front, like those on the Scuderia/16M and, I think, the 599. Stickier tires will wear brakes faster.
    Movit CER brake pad & rotor wear data
    I am collecting wear data on Movit CER (carbon ceramic) brakes for the Manufacturer (Movit). Here's an excerpt I thought may be of interest on this thread:
    "I finally had to change the first set of front Sport pads on the CER rotors. Here’s the data:
    New pad thickness = 10mm
    Use = 19 track days; 2644.8 miles
    (Texas World Speedway, 2.9 miles, average = 4x 24-minute track sessions per day, 12 laps per session, 139.2 miles per day)
    Thickness remaining on worn Sport pads:
    Rear
    Right Rear Inner = 7-8mm*
    Right Rear Outer = 8-8.5mm*
    Left Rear Inner = 8mm
    Left Rear Outer = 8-9mm*
    Front
    Right Front Inner = 5-6mm*
    Right Front Outer = 5-6mm*
    Left Front Inner = 5-6mm*
    Left Front Outer = 6-7mm*
    *pads were tapered at leading edge
    No measurable wear on rotors.
    I replaced the front pads. I anticipate another 2500 miles of track use from the rear pads. Front Sport pad wear has been significantly better than PCCB pad, which averaged 6 track days per set "
    CER rotors are 350mm x 34mm front; 350mm x 28mm rear. Car is 3500 pounds (Porsche 996 Turbo, full wet w/driver). CER rotors are made from same carbon-ceramic material as Ferrari and Porsche PCCB rotors; Panox from Carbon SGL in Germany. But the construction method is different; hence the better wear characteristics.
    Taz
    Terry Phillips
  9. M-individual
    M-individual F1 Rookie
    Oct 5, 2007
    2,937
    GTO, 458C, GT3RS
    Hi Terry,
    Very interesting. For what it's worth: wear measured by the dealer after the full day at Spa:
    front: 4%
    rear: 0%
    So in the end, this wasn't all that bad and I have to say that the brakes on the GTO are stunning.
  10. tazandjan
    39,174
    M- Was that the pads or the rotors? Not too bad for Spa, which is a really high speed course with heavy braking for low speed corners.
    Taz
    Terry Phillips
  11. Ferrari 360 CS
    Dec 4, 2004
    6,888
    Cape Town,SA
    Jacques
    Very good wear rates for a high speed braking track like Spa!
