GTO brake pad (Pagid) | FerrariChat
Discussion in '612/599' started by Ahtim, Aug 29, 2021.
  1. Ahtim
    Ahtim Karting
    Nov 8, 2018
    92
    HK/China/England
    W
    Hi, from my understanding the stock GTO’s brake pad are made by Pagid, does anyone know if the rsc1 the same as the one stock GTO’s pad or is it better? Is it necessary to upgrade to rsc2 or 3?
    Thanks in advance
  2. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Quite sure it is just the regular T4300 Textar compound found in all of Ferraris OE pads, being it for an Enzo, Laf, Cali T or F12. It is also the compound GM has used on the Corvettes with ceramic brakes since the C6. It's a 25+ year old compound developed by Textar which is owned by Pagid for Brembo as a budget friendly OE alternative to more expensive compounds. The RSC1 is a much newer compound which is similar but of a better quality and manufactured by Pagid.
    Does the GTB and GTO share pad shape?
    of2worlds likes this.
  3. Ahtim
    Ahtim Karting
    Nov 8, 2018
    92
    HK/China/England
    W
    Yes GTO and GTB use the same size pad, the calipers are the same, currently I am using ss hose lines and SRF fluid, stock pad and disc, I am thinking to upgrade the pads with Ccm disc any review from RSC1/2/3? I do a lot of track days with my car on the big tracks, and some road trips but not much around town.
  4. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    You're right. Looks like the front size has been discontinued.
    It's not a problem finding wheels equally light.
    If you order these in 9.5"x20" front and 11.5"x21 rear with OE offsets, then you get a set of wheels that will be as light, if not lighter than OE.
    https://forgeline.com/wheel/gs1r
    The GSR1 is a well proven and very strong wheel, that is about as light as forged alloy wheels come.
    Then run them with the Dunlop Sport Maxx Race 2 in 295/30R20 and 325/30R21. Those are the tyres off of the GT2RS with the Weissach pack. The Cup 2 Track Connect is also available in this size if that's what you prefer, but the Dunlops are the grippier of the two.
  5. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    In that case, try the RSC2 pads. The shape you need is the same as the 458/599 GTB then.
    I have tried them on the Pista and 488 and been very happy. Last a lot longer on track and still very streetable with much better track performance in conjunction with the Castrol fluid.
  6. Ahtim
    Ahtim Karting
    Nov 8, 2018
    92
    HK/China/England
    W
    Thanks A lot!
  7. Ahtim
    Ahtim Karting
    Nov 8, 2018
    92
    HK/China/England
    W
  8. Phil57
    Phil57 Rookie
    Feb 7, 2020
    14
    France
    Philippe
    OEM pads versus Pagid RSC1:
    Engraved on both pads = Textar T4300 !!
  9. FerrariFinally
    FerrariFinally Formula Junior
    Nov 11, 2018
    558
    Roseville, CA
    Kevin
    Great info here!
