GTS Door Glass U-Channel | FerrariChat
Discussion in '206/246' started by racerboy9, Jun 15, 2019.
  1. racerboy9
    racerboy9 F1 Rookie
    2,645
    It looks like the original (I assume) U-channel was glued in. Can anyone corroborate this? Does it really need to be glued in?
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    I never glued mine in, the shape of the u channel more or less squeezed into the frame and made it a tight fit anyway.
    Tony
  3. racerboy9
    racerboy9 F1 Rookie
    2,645
    Thanks Tony. I am glad to hear yours is working fine with no glue. Mine looked fully glued in but that looked like overkill. I might put a small dab at the top, middle and bottom for piece of mind.
  4. Eltel246
    Eltel246 Karting
    May 14, 2012
    180
    London
    Charles Hill
    Just changed the original channel on mine and it was definitely glued in.
    synchro likes this.
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Second owner of 05702, both channels had a sloppy amount of glue applied and believed to be OEM
    That being said, I was in there looking because of slow window movement. i found that cutting the bottom few inches off the channel facilitated window movement and it is well within the door so nobody sees it and there was no interference or rubbing
  6. TTR
    TTR F1 Veteran
    5,890
    Riverside, CA
    Timo
    FWIW, most of the 365 GTB/4 door (sliding) glass channels I’ve worked on have appeared to had glue used for their (presumably original) installations and given that both models, if I’m not mistaken, were constructed at Scagliettis during same time period...
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Correction "RUBBER " added
    I did not mean to infer cutting the metal structure
  8. pshoejberg
    pshoejberg Formula 3
    1,823
    Denmark
    Peter H
