GTS sun visor end caps | FerrariChat
Discussion in '206/246' started by mar3kl, Aug 14, 2018.
  1. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    I just noticed one of the clear plastic end caps on my roller shade sun visor is missing. I was thinking about replacing it with a clear vinyl screw-thread protector of the right diameter but I can't find one anywhere. Any bright ideas for a solution that looks more or less correct?
  2. er72
    er72 Formula Junior
    322
    Roslyn Harbor, NY
    Eugene
    Search Google for clear (transparent) suction cups - there are plenty available, I just don't remember the correct diameter
  3. mar3kl
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    I have the suction cups, what I’m looking fo are the clear end pieces that slide over the rod at one end of the roller blind. It looks like a small enough screw thread protector would work, but I haven’t been able to find them in clear.
  4. mar3kl
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    They aren’t, although maybe I could cut the flange down to fit. I suspect 8mm is too wide though.
  5. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,330
    Iain
  6. mar3kl
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    That looks exactly right. I wonder what a “headband end” is though - half the battle with these sorts of treasure hunts is finding the right search terms.
  7. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,330
    Iain
    The seller is based in Australia so I suspect it is literally meant for metal bands to hold surfers hair back etc. It is the exact same item fitted to my original GTS visors though and is just a universal clear rubber end cap. Mine have yellowed with age but would have been clear when new I suspect.
  8. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    I have these on the inside position only at center of car but not on outside edge. Also I see on p. 219 of Compendium
    Are your sunshades blue on outside one and beige on inside of shade? or blue on both sides?
  9. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    Blue on the windshield side and Tan on the drivers aspect side.
    The “Endcap” rubber piece is only on the rear view mirror side of both shades. I am guessing place to prevent the metal edge on the lower part of the shade from banging into/damaging the rear view mirror, which would be a “guess”.
    Shawn
