GTSi Coil problem and Ignition Questions? | FerrariChat
Discussion in '308/328' started by Big Daddy, Nov 7, 2011.
  1. Big Daddy
    Big Daddy Karting
    Jan 3, 2009
    212
    Albuquerque, NM, USA
    RJ
    Yesterday the front bank went out on my 81 GTSi, but the rear bank was still running perfectly. I noticed that the front coil is cracked, and figure I need a new one. To make sure that was the problem, I reversed the digiplex connectors. No change, so they must be okay.
    Then to make double sure I reversed the green and yellow/black signal wires and the coil to distributor leads. (Both coils were receiving 12V from the yellow wires.)
    I cranked the engine and it would not start at all. Both banks are out.
    I understand the rear bank not firing now if that front coil was bad, but why is the front bank not firing using the rear coil? There seems to be no spark at either coils.
    Could there maybe have been a problem elsewhere in the ignition system which led to the front coil burning out? The only other thing I know of would be if the front crank sensor was bad, but I never heard that could damage the coil. It seems unlikely they would both have gone out at the same time unless there was one cause for both.
    Or could the coil burning out have caused something else to go, perhaps a fuse or fusible link that I don't know about? And now there is no signal to the coil to fire?
    Any solutions to this mystery would be appreciated!
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Did you verify no spark with a tester? I would check to see if the front plugs became fouled and are just grounding out as I imagine the coil was weaker for some time and if you did the swap and try to restart it right away you may have flooded front bank of the engine.
  3. BigTex
    79,380
    Houston, Texas
    Bubba
    Because it's using the other crank sensor??
    If you suspect a coil bad I'd change it, as it is cheap, and not run the risk of damaging the old digiplexs messing around.
    Losing the ground even, can burn them out?
  4. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    The way I read it is he changed the wiring for each coil and that should allow it to run.
  5. Big Daddy
    Big Daddy Karting
    Jan 3, 2009
    212
    RJ
    Thanks for your input. I think the way to proceed is to replace the obviously damaged coil, and proceed from there. If there is another issue, I can hopefully trace it back from there.
