Gtsi Fuel Accumulator | FerrariChat
Discussion in '308/328' started by XLR8KWK, Jan 21, 2014.
  1. XLR8KWK
    XLR8KWK Rookie
    Jul 16, 2009
    27
    FLORIDA
    CARL STEINBERG
    I removed the fuel pump to replace it and also removed the fuel accumulator. When I removed the fuel accumulator, fuel also came out of the small curved vent at the back. I am assuming that the accumulator is also bad since fuel should only be in the end with the fittings. Is this correct?
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Fuel should not exit via the vent tube on the bottom.
  3. XLR8KWK
    XLR8KWK Rookie
    Jul 16, 2009
    27
    FLORIDA
    CARL STEINBERG
    Thanks-that's what I thought-I will add that to the list.
  4. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    is this the definitive test on this part?
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I believe that yes, fuel leaking woud indicate that the diaphragm is leaking and allowing both pressure loss (hard warm start) and fuel to leak from that little tube. Only fix is to replace.
    See: http://www.ferrarichat.com/forum/mondial/424171-fuel-accumulator.html
    for a brief confirmation.
  6. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,218
    Gold Coast, Aust.
    Patrick
    One of the PO's of my car connected the vent tube back to the fuel tank breather! I believe it's there as a tell-tale for a faulty diaphragm
  7. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
  8. phrogs
    phrogs F1 Veteran
    7,345
    Kzoo Michigan
    If you need one I have a brand new one I didn't end up using I'll let go for a fair price pm me if your interested.
  9. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I believe all USA cars had that tube routed back into the tank. TAV11 on the 308QV USA clearly shows it. I don't know if ROW cars had that or not, but the Euro 308QV diagram on Ricambi's site does not show it.
  10. XLR8KWK
    XLR8KWK Rookie
    Jul 16, 2009
    27
    FLORIDA
    CARL STEINBERG
    I ordered one from FcpEuro for $98.95.
