GTSi fuel pump banjo fitting | FerrariChat
Discussion in '308/328' started by XLR8KWK, Jan 29, 2014.
  1. XLR8KWK
    XLR8KWK Rookie
    Jul 16, 2009
    27
    FLORIDA
    CARL STEINBERG
    #1 XLR8KWK, Jan 29, 2014
    Does anyone know what size banjo these new fuel pumps require-the one in the picture is too big. I am trying to find out what i need to ask for.
    Thanks for the usual excellent help!
  2. Steve Magnusson
    26,626
    What "new" fuel pump? Do you have any manf part number/info/specs? (Doesn't look beefy enough to generate the ~6 bar pressure needed for CIS operation.)
  3. Conchyjodyoos
    Conchyjodyoos Formula Junior
    263
    FL450
    Following this thread also, I just ordered a new fuel pump (bosch 69532) yet to arrive but thought it should be a plug and play along with the accumulator.
  4. tepps
    tepps Karting
    Oct 15, 2010
    103
    Buffalo NY
    Tom Tepas
    The banjo fitting would be described by its metric internal diameter.Such as 14, 15, 17, 19, mm. Looks like you have a Pierburg pump .Should work, but I would not modify my fuel lines to accept an aftermarket pump unless the money differential was significant. Tepps
  5. mwr4440
    57,859
    Bavaria, The 'Other' Germany
    Mark W.R.
    #5 mwr4440, Feb 2, 2014
    Should not be an issue.
    The plastic fuel lines of the "i's" should ALL BE REPLACED, if they have not been done in the past say 10 years. All 13 of them (on an '81), if original, are just a fire waiting to happen.
    A new banjo should only be a couple of bucks from Bosch.
    All that said, I'd just buy the correct fuel pump from Bosch. They are not expensive even for a cheap-skate like me.
  6. XLR8KWK
    XLR8KWK Rookie
    Jul 16, 2009
    27
    FLORIDA
    CARL STEINBERG
    Here's my update:
    When the fuel pump went out, I thought I would check locally since it was a Bosch fuel pump. The pump shown in the picture is that pump. When i got home I noticed that it was different, so I went to the Forum to check it out. Here is where thisng went screwy-i must have pulled an old post that mentioned that the pump I needed was NLA. i Guess that a few years ago this may have been the situation. When Steve mentioned "what new pump" i went back to the Forum and found this was old info-thanks Steve. I returned the wrong pump and ordered the new pump and all is now good.
    Thanks for the usual assistance!
    Hope to start it up this weekend.
  7. Dave MacLeod
    Dave MacLeod Karting
    Mar 22, 2008
    60
    Sydney, Australia.
    I just changed out the fuel pump and fuel accumulator on my gtbi, went a slightly different route with the connections. Turned out well.
    Dave.
  8. 1Evil4re
    1Evil4re Formula Junior
    Jun 24, 2012
    313
    Nashville Area
    David
    Very nice!! Well done.
  9. Exact10
    Exact10 Karting
    67
    Pleasanton, CA
    Annie's Daddy
    Dave,
    I've just taken the pump out of my 82 GTSi, the pipe that goes from the accumulator to the pump is shot, has broken off at the fitting, do you mind telling me where you got the new fitting and pipe
    Ian
  10. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    i'm having a new pipe fabed at a local machine shop.
    basically they're reaming the old tubing from the banjo and flare fitting and brazing the new tubing in.
  11. mwr4440
    57,859
    Mark W.R.
    Ian,
    You can get a new one from any of our regular parts suppliers.
    I have a spare on the shelf ini the event of an Ah-S**t.
  12. craiggo
    craiggo Formula Junior
    411
    Redwood City
    Craig
    Like whom? I can't seem to find one. If mine breaks tomorrow, I'm going to be desperate for one myself.
    Craig
