Guess what? | Page 3 | FerrariChat
Guess what?
Discussion in '348/355' started by ernie, Nov 9, 2010.
  1. Dave Monk
    Dave Monk Karting
    Apr 23, 2010
    213
    SW Virginia
    David Monk
    If there is stuff coming out of your exhaust did you consider that your cats are breaking up and pieces of them are blowing out? Could be most of your problem if pieces are blocking exhaust flow.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
    Broken ceramic does not look like little white hairs. Besides I have metal core cats. Thanks for the suggestion though.
  3. Dave Monk
    Dave Monk Karting
    Apr 23, 2010
    213
    SW Virginia
    David Monk
    You are correct, most of the time it looks like chunks of stuff not hairs, but then I don't know how high flow cats are made. I am struggling with how the exhaust manifolds could "suck" in air as they should always exhibit positive pressure which would always push material out. At any rate, if I think of anything else I'll post, good luck...
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,696
    San Carlos, CA
    Mitchell Le
    That is not true. They are "mostly" positive pressure.
    Look at the 328 exhaust. It has a fresh air passive injection system that "sucks" in fresh air from the airfilter using just vaccum on the exhaust. There is a one-way valve in the air injection stream such that air flows in when there is exhaust vaccum. This system does not work as well as an active air injection system, but it does work.
  5. fatbillybob
    Aug 10, 2002
    29,376
    socal
    1) why bother...you are just going to do it your way while I sit back and eat chicken wings.
    2) actually, what are you doing Friday afternoon or this weekend?
    What condition is the car in now? Does it run? If yes do not take it apart. You need to diagnose where the miss is coming from. Do you really have a miss or do you think you have a miss? All you said was headers. You got a crack, burn hole, leaky gasket? What? And you will be screwed with CARB 100% guarantee. Do they look like burnt 355 headers? If not I can fix them 99% of the time. I got MIG, TIG and just about every flavor of welding wire.
  6. MarkJ
    MarkJ Formula Junior
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    I love these diagnostic threads. Always learn something.
  7. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Ernie,
    You've been the essence of the Brotherhood ever since I can remember, always first in line to help novice 348 diy'ers diagnose, fix and lend support for their problems. It's rare to see you bummed out... I hope big-D and FB can help you work through this.
  8. ernie
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
    #58 ernie, Nov 11, 2010
    I have an appointment with the drill bit operator for a checkup in the morning. But I'm still pulling the headers tomorrow. So if you wanna drive up I'll feed your face. Or maybe not, cause then I might not have enough money left over to pay for headers. :p
    It "runs" but doesn't run. The problem is I don't have the stock injectors in it. I tested out a set of 24lbers I got from Vince and the Motronic HATED them. The ecu's threw check engine lights with in minutes of start up, and on both banks. So........I don't wanna turn the car on again until I get the injectors checked out. I'll be shipping them off to Mr.Injector for testing and cleaning. Which is another thing I need to do tomorrow.
    And I REALLY have a miss. It can be heard distinctively at idle. Well when the old injectors were in anyway. So the car won't be started again until I get the injectors back from testing and cleaning. Though at this point I don't think it's the injectors. I'm still shipping them off cause I know they have never been touched since they went in at the factory 20 years ago. A good scrubbing behind the ears will do them good.
  9. ernie
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
    #59 ernie, Nov 11, 2010
    Thanks for the sentiment Troy.
    And yeah I am bummed. It gets old time after time that as soon as I fix this b!tch something else pops up. This isn't the 3rd, 4th, 5th, or even 6th time something like this has happened. It's almost like it happens every time.
    Example.
    A spot weld in my gas tank pulled out = gas leaking out of the tank. Dropped the tank to get it repaired to find the rubber boots around both fuel pumps were deteriorated. So I get the pumps taken care of, the tank welded up, put it back in, then a stupid purge valve goes bad, resulting in the my JUST FIXED tank starting to get crushed like a beer can.
    And I have many other examples like that.
    It's really old, and I'm pretty sick and tired of it. My problem is that I'm too bull headed to know when to quit.
  10. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    #60 davehelms, Nov 11, 2010
    ""why bother...you are just going to do it your way while I sit back and eat chicken wings""
    The wise old fat man speaks the truth! My concern is there are new owners or potential owners reading this and thinking this is how it really is. There is always a way to prove a convoluted theory as long as facts don't get in the way.
    Do you HEAR an exhaust leak? If a deaf old turd like me can hear a slightly cracked header on a 14:1 race engine with a 330+ degree cam running straight pipes... you can damn well HEAR it on a stock muffled engine. If they are broken, by all means fix them but do not expect that to fix a flat tire.
    Unplug the O2 sensors and go for a drive. That will either confirm or blow a hole in this WAG. Unplugging two connectors putting the engine into open loop beats the hell out of pulling a pair of headers in my book but hey... I'm new at this. Is the miss gone? No? Then that doesn't even come close to proving your theory correct but it does give clues to a direction, none of which involves removing headers! Are your multi values HIGH or LOW? Don't know? Why would you go through the PITA to remove headers until you know? Is it a lean miss or a rich miss? What bank is the miss? What cylinder or is it random and floating on one bank?
    MECHANICS 101! Identify, diagnosis (!), confirm and game plan, repair, verify and final check.
    No where is the afore mentioned logic path is "WAG involving fuzzy things". Fix the car properly based on facts and logic and THEN while your relaxing after a rewarding, fun drive build a new Space Age harness and redesign headers if that still trips your trigger. It is very easy to get into the mental rut you are in, we spoke about this. This is the point where you step back, take a breath (of FRESH air), gather facts and move forward with a plan based on those facts.
    I am in exactly the same rut working on a serious problem with the Bosch engineers regarding the 355 out your way. Four weeks of notes and research was put in a file and a fresh new legal pad pulled out after an hour long conversation last evening with some pretty smart folks. Some times its the only way to pull open the blinders... I'm there myself. Your problem? That is simple stuff, you can HEAR and FEAL it... I wish that was the case with mine! In my case we both have hard facts proving two opposite theories. You want to talk about "Bull Headed"? I'm the only one NOT getting paid to figure this out, that goes well beyond bull headed and firmly planted in "Dumb Ass" territory. After 40 yrs you would think I would know better!
    You cant work on these cars with blinders on. That is the cause (based on what I have read only) of many of your follow up problems. Work on a system, fix it properly and completely ONCE and then move on to the next.
  11. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,238
    Huntsville, AL., USA
    Andrew
    Or is your problem that you can always remember how good it is on the days when everything is actually working as it should and consider that worth the perseverance? ;)
    Hope you're back on the road again soon, Ernie. :)
    All the best,
    Andrew.
  12. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Q: How can insulation from the headers make it through the cats?
    I agree, more diagnosis is needed. Has the compression been tested? A misfire can be caused by a leaky valve. Or by a bad injector, or a plug with a cracked insulator, even by oil usage in that cylinder, where the oil residue short circuits the spark. Not immediately and not always but still with a degree of regularity. It should be easy to find which cylinder it is, unplug the injectors one by one checking for the popping noise changing - if the misfire gets worse then the cylinder you unplugged is not the culprit. Then diagnose further by checking out the injectors or swap them to another cylinder.
  13. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    #63 troy_wood, Nov 11, 2010
    Buying these cars is easy. What truly sets the bonafide Ferrari owner apart from the rest is his/her ability to perform the hardcore maintenance. Not the plugs and oil but the real heavy lifting ****. I'm certainly no where close to expert but I do know from other facets of life that the art of good diagnosis falls within the 'heavy lifting' category.
    I think you are on the cusp of achieving that next level and this is your final test.
    Hoard in the intellectual capital to be gained from this last hurdle.
    Wish I could help. Perseverance baby!
  14. fatbillybob
    Aug 10, 2002
    29,376
    socal
    I can't get up there today. I think you should put the old injectors back in so that you can diagnose the problem today. If you send them out you could get lucky and they need to be cleaned anyway but if that does not work you just delay the diagnosis another 2 weeks. Taking the headers out today will only open a new can of worms. You will do something like brake off a header bolt to the level of the head casting and then moan about how to take that out without ever confirming the header theory. Why cause more problems. The 348 headers are pretty stout and can take some significant vibration. Besides your car does not run enough to damage them anyway. Now that was a kick below the belt!
  15. ernie
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
    #65 ernie, Nov 11, 2010
    Well lookie what Ernie found.
    Before I shipped the injectors off I decide to have a good look at them. The tip of the #4 injector (top pic) is CRACKED! and have a look at the condition of the o-ring on the #8 injector (2nd from top pic). That o-ring has seen better days big time. These things are beat up pretty good, and definitely need a good scrubbing. So I'm not gonna plug anything back in until I get these back from Mr. Injector.
  16. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    I'm bettin' the o-ring problem in 8 is a bigger one. The cracked tip is rather routine and can be replaced with $1.50. What's the plug in 8 look like? Is it lean?
  17. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    Now *that* looks like a problem and adds up (at least to me) why Eric's fuel rails with gold connectors only partially solved the issue.
  18. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Attention to the seemingly small details, the difference between drivable and running Correctly.
    I'm with Bruce, the cap isn't much of a concern but a vacuum leak sure could make a difference. Unless there is one heck of an ugly injector.... you are only part way to the fix. I would bet you are dealing with no less than 4 small problems that add up to what you can hear and trip the CEL.
    As long as you are working on the injectors, check the WHOLE fuel system and put that to bed. Remove the fuel filters, shake them up real good while holding the ends capped and pour them out backwards onto a white paper towel. Still perfectly clean from the pump over haul procedure? Any debris showing? Debris from what source? Freshly serviced injectors require this double check so they are not put in jeopardy once running again. Rest assured, those filters do not catch all the debris, you need only pour a dirty filter out on a clean paper towel the direction of flow to prove that fact!
    Fabricated fill neck and vent tubes still completely intact? New orings should go on the vent pipe connections..... Cover every Fuel System component now and then put any question to its integrity to rest for good.
    Assumptions lead to oversights and missed opportunity in diagnosis.
  19. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Previous fuel pump gasket failure augurs toward Dave's recommendation.
  20. ernie
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
    I have two new fuel filters and will be changing those out. As for the o-rings on the vent nipples, changed those out before I put the tank back in. The filler lines are good for 5 years, but I'll double check them anyway. Think I'll go ahead and put some fuel pressure gages on the rails, after the regulator, while I'm at it.
  21. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    Nice to see the brotherhood working together.
  22. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    #72 troy_wood, Nov 12, 2010
    +1
    I really like the concept of working thought a complete 'system' before moving on. In this case Ernie is putting the whole fuel system to rest via working on it's individual parts.
    Dave is handing out gold bars for free here....
    Ernie, let me know if you need someone to take any sort of baseline values on a stock, good running 348.
    This is a good thread.
  23. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    ERNIE ---
    Have you tried swapping the entire car with a 360 :p !!!
  24. MaterMech
    MaterMech Formula Junior
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    Any garbage in the filter baskets of the injectors? How bout a plug read on all 8? Been wondering how to check lamda values without SD. Any way to check additive/subtractive values?
  25. ernie
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
    Haven't pulled them to have a look since I swapped things.
