Guys I have a few problems need help! | FerrariChat
Discussion in '360/430' started by Madmag, Jul 31, 2023.
  1. Madmag
    Madmag Rookie
    Aug 5, 2022
    35
    Oscar franjul
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,933
    Central NJ
    Dominick
    Bad /weak/old battery
    Either intake gasket or coil issue
    That would be the the two educated guesses
    Replace /charge battery ..wipe codes and see if misfire comes back ..if so check intake gasket and / or move coils around and see if follows.
    fstbiker likes this.
  3. Madmag
    Madmag Rookie
    Aug 5, 2022
    35
    Oscar franjul
    I change the coil #6 and the battery is charge I don’t know If I need to
    check something specific in the battery volt o something
  4. LorenzoR
    LorenzoR F1 Rookie
    how old is the battery
  5. Madmag
    Madmag Rookie
    Aug 5, 2022
    35
    Oscar franjul
    Have a few years I think
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,933
    Central NJ
    Dominick
    Connect a voltmeter to battery ..record voltage ...start car and while cranking record voltage ...let idle record voltage
    Display three numbers here
  7. Qavion
    Qavion F1 World Champ
    14,292
    Ian Riddell
    What made you run a scan on the car? Just routine maintenance? Were there any fault lights before you started working on it? Was the engine stumbling? Is there an airbag light?
    Note that the Airbag ECU and the suspension ECU share a common fuse. The airbag faults and the roadbed roughness fault may have a common cause.
    Have you tried searching on this (360/430) forum for the specific codes? e.g. "P1619" (Roadbed Roughness).
    https://www.ferrarichat.com/forum/posts/148042724/
  8. Madmag
    Madmag Rookie
    Aug 5, 2022
    35
    Oscar franjul
    I put the scan because I feel the car slow and stumbling. I have the airbags light in the dash on, ASR, abs and some times the check engine light too
    Qavion likes this.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,933
    Central NJ
    Dominick
    Alot of what you are say/showing can be a weka battery ..please report back the numbers I asked for above
    SoftwareDrone and Qavion like this.
  10. LorenzoR
    LorenzoR F1 Rookie
    I'd go buy a new battery
    RANDY6005 likes this.
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
  12. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Amazon sells these. $40ish, delivered to your door the next day.
    You’ll have it forever and can use it on all your cars.
    Like everyone else has said, sounds like a low battery, which you’ll never know until you load test it.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,567
    San Carlos, CA
    Mitchell Le
    My neighbor across the street have the ****tiest time with his car batteries. He replaced both batteries in his two cars, then left them sitting for two months while they went on vacation. Up on coming back, one of the two new batteries have died permanently.
    So a few-years-old battery, who knows ?
  14. LorenzoR
    LorenzoR F1 Rookie
    Sometimes I leave for 2 months to. A battery maintainer goes a long way. If I were op I'd start fresh with a new battery
  15. PKIM
    PKIM Karting
    Jan 1, 2004
    199
    Redlands
    Paul
    The misfire can come from over filling the oil. Check the oil level, check the MAF and make sure there is no oil. You might want to clean the MAF.
  16. Scottslaw
    Scottslaw Formula Junior
    yeah, seriously. Just buy a new one and start fresh. That will GREATLY assist your troubleshooting.
    LorenzoR likes this.
  17. bernieb
    bernieb Karting
    Apr 16, 2007
    215
    Alberta Canada
    Bernard J Bonertz
    Take the Effing car to a dealer or a knowledgeable indie. good christ!
    KC360 FL likes this.
  18. yelcab
    Nov 29, 2001
    13,567
    San Carlos, CA
    Mitchell Le
    C'mon Bernard. This is mostly a DIY site. What fun is taking the car to a dealer each time.
    bernieb and Qavion like this.
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Thing is, you dont switch the charger on- always watching the electric bill. Do you still have that extension cable connected to next doors garden shed supply.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,933
    Central NJ
    Dominick
    Now do the crank test and voltage test without car running
  21. LorenzoR
    LorenzoR F1 Rookie
    Yea my next door neighbor has a outside outlet on the side of his house. I run it underground lol
  22. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    No wonder you are the richest man on the block- just finished changing all the cooling water hoses on the car- you need small fingers and a mirror to do those on the water pump. Vac device worked well after i modified it.
