355 - Hacking the F1 TCU | Page 4 | FerrariChat
355 Hacking the F1 TCU
Discussion in '348/355' started by Wolfgang72, Jul 12, 2019.
  1. Wolfgang72
    Wolfgang72 Rookie
    Jul 12, 2019
    45
    Munich, Germany
    Wolfgang Schmidt
    #76 Wolfgang72, Apr 16, 2020
    In the automotive industry the development of an ECU of this complexity takes around 5 years. Usually two departments are involved, the hardware department and the software department. A typical software department consists of around 100 employees (architects, function developers, implementers, calibration engineers, testers, ...) while a hardware department is maybe half the size. Now let's do the math: 5 years * 150 engineers = 750 man years of development. If you are able to outsource half of that work to best cost countries, the average costs for an engineer are around 70k. That results in total costs of around 50M!
    But that's only the labour! You'll need office space. You'll need equipment, tools, test benches. You'll need prototypes. And so on. That will easily double your costs!
    Maybe you intervene now and tell that a "start-up solution" is enough. Plus part of the software is already there and only needs adaptation. But how much will that cut the costs? To half of that? A quarter? Even at 10% - which I'd consider as unrealistic - we're talking about 10M! And we still left out the risks. Will you find smart specialists that have experience in this area? Will they harmonize as a team?
    Maybe you throw in that there is stuff like Megasquirt which could be used. And that's absolutely valid. Those boxes are even used in Motorsports and do a good job. But my customer is not asking for that. He is having a vintage Ferrari in his garage and seeks for a decent solution.
    I truly appreciate your question. However a complete re-design of the ECU was definitely out of scope.
  2. brogenville
    brogenville Formula 3
    2,324
    Robin
    Yeah... it doesn't sounds straightforward. :p
    So whilst (I think) you accept that a whole new ecu would have better long term prospects for making improvements to speed, smoothness etc., its just not viable. Hence you're looking to find areas to optimise the firmware in the existing ecu.
    Fair play... still curious to learn how this unfolds!
  3. tres55
    tres55 F1 Rookie
    3,573
    Canada
    Forgive my ignorance but short of swapping out solenoids and pumps for the entire system (alongside TCU improvements) isn't the major limiting factor here the fact that it's a single clutch F1 transmission?
  4. snerrio
    snerrio Rookie
    Apr 21, 2020
    3
    Antwerp, Belgium
    Mathias Serneels
    Hi guys,
    I am completely new here, but trying to find my way in the Ferrari scene!
    I read a lot of interesting stuff here and was wondering if any of you has experience with the type of damage to these electronic components when they fail?
    I have a TCU of an F355 that has the defect that it does not want to shift, or when in gear, throws it back to neutral whilst giving a beep and a flashing "N". Lots of things tested, hydraulic pump, potentiometers in actuator, etc...
    In the end swapping the TCU did solve the issue. New TCU's are expensive and I do have several contacts to have electronics repaired. I have the idea that Wolfgang72 in the meanwhile became quite an expert on the matter :), so maybe you can help me out here?
    Regards,
    Mathias
  5. Qavion
    Qavion F1 World Champ
    14,615
    Ian Riddell
    Welcome, Mathias! I don't think Wolfgang72 comes to the forum so frequently, but if you add some details to your profile page (country, especially), perhaps someone can point you in the right direction. A quick search of the forum didn't result in much luck. Your best bet may be a second hand TCU.
    Apart from Wolfgang's picture of his new circuit board, I found I found some pictures of the internals here:
    https://mhhauto.com/Thread-Electronic-Circuit-Control-Module-Hardware-Repairing?pid=1322910#pid1322910
    Perhaps you could open up the TCU and look for obvious faults. Most parts will be off-the-shelf items. In some cases, resoldering the main connector pin board conacts may fix the problem.
  6. snerrio
    snerrio Rookie
    Apr 21, 2020
    3
    Antwerp, Belgium
    Mathias Serneels
    Hi Qavion,
    Thanks for the reply. Will update my profile page.
    Regards,
    Qavion likes this.
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I,am with Ian on that.
    Just had one of my Cat excavators dash panel fixed For 150 bucks but they wanted 3300 for a new one.
    I do not know enough to fix these but the guy who did said there are quite a few advances out there in electrical diagnosis boxes.
    he seemed to have things which could test all the components live under load 1 by 1 and tell you which was bad.
    Quite often he said it is not the chips
    In my case it was the coil which I noticed looked odd as well. He built me a new coil and all good
  8. snerrio
    snerrio Rookie
    Apr 21, 2020
    3
    Antwerp, Belgium
    Mathias Serneels
    In my case the workshop does have the diagnostic tool. So I asked for the errors, in this way I can trace the pins on the connector and hopefully discover which circuit inside gives me the errors. I believe it is fixable, at least I'll try.
    These sensitive electronics do have a hard time in cars with a stiff suspension.
    Regards,
    Mathias
    Qavion likes this.
  9. Wolfgang72
    Wolfgang72 Rookie
    Jul 12, 2019
    45
    Munich, Germany
    Wolfgang Schmidt
    Part 9 of Hacking the F1 TCU
    Intel, the well-known chip manufacturer, was known for a long time for its so-called Tick-Tock model. Instead of developing a completely new CPU each time, they devided the job into two halves and alternately did only one of it: either renew the CPU architecture (Tock) or perform a die shrink (Tick). That is when they released a new CPU, it was actually only half new (and half similar to its predecessor). This strategy saved them a lot of effort and costs. Interestingly Ferrari does something very similar with their V8 models: a new development of the bodywork is followed by a new development of the drivetrain. Therefore the shape of the F355 is similar to the F348, while its drivetrain is rather close to that of the F360.
    It suggested itself to compare the drivetrain of the two! I wanted to see which improvements Ferrari made to the F1 in the F360. I already knew that shift times are also rather slow there. However, during my search I found out that there is a special situation with the Challenge Stradale. I read that at least for that model shift times are considerably better!
    I was curious about what the difference would be. I continued my search and stumbled across this thread. Unfortunately it doesn't mention any internal details on the difference. However it makes a clear statement: the CS TCU can be retrofitted into a Modena! Better still, it's only a matter of flashing the CS software!
    This gave me further confidence that I was on the right track with my approach. If it's only a matter of software to achieve faster shift times in the F360, then this would definitely apply for the older F355, too! I had to find out what was improved there and then port this into the F355 Software! Or better: I would port the entire software of the F360 CS TCU into the F355 TCU! Mmh, would this be possible? I planned to buy an F360 TCU to have a closer look.
    There is only a single TCU variant in the F355. It is called CFC-101. However for the F360 several variants were made. If I got it correctly, then the oldest is from the Modena and dates back to 2001. It is the CFC201F.01. Then later there was an update to the CFC201F.05. Finally the most modern variant is that of the CS, which is called CFC231. This was the one I was looking for!
    Unfortunately, these units are rare and so I couldn't find an offer. But finally I found a CFC201F.05 which is said to be compatible with the CS. I bought it immediately and it arrived a few days later. I opened the case and checked the hardware.
    It was not much of a surprise that the hardware is different:
    Unfortunately after a more thorough check I found that the differences are substantial! Though I recognized a similar structure, I noticed that innumerable details have been changed. Well, at least the processor is the same. These are the major differences:
    Next, I analyzed the software. I retrofitted the debug interface and dumped the code. I looked at it and discovered many functions which are completely identical. Then again I found some that differ only by minor things. But in the end I noticed that the majority of functions changed completely or are even new.
    What a pity! Anyways, I wanted to try out whether the F360 software can run on the F355 TCU! Simply copying it wouldn't work now, of course. But I would do an adaption then. I went to work. Looking back the most difficult thing was to redesign the pin assignment of the processor. But also many other small details took so much time.
    After all I think I've come quite far. I was able to basically make the software run on my F355 TCU! Gear indicator, switch, buzzer, relay, etc. - all that stuff was working! I was even able to shift gears using the diagnostic interface! However, the TCU refused to release the engine start inhibit. I tried a lot, but always got stuck in things where I did not (yet) understand the software well enough.
    I decided to put this approach on hold. Maybe I would come back to it later. But this episode taught me two things: the F360 TCU bases on the F355 TCU. And that the key to faster shift times is in the software!
    Skippr1999, brogenville, 601 and 2 others like this.
  10. Qavion
    14,615
    Ian Riddell
    Wolfgang, I'm not sure I completely understand your reasoning. The 360 gearbox/power unit (mechanicals) may have been over-engineered on the 360 allowing software tweaks to let the mechanicals to reach their full potential.
    A computer analogy: You can overclock CPUs in PCs, but sometimes you can only do this if you, say, improve CPU cooling. A system is only as good as its weakest link. You can have the fastest processor on the planet, but if you have, say, slow hard drives or busses, you won't reach the maximum potential of the processor.
    Of course, we don't want to discourage you in your efforts.
    Does anyone know if the 360 has any additional engine starting requirements? Or do, perhaps, the inputs for start have different values (e.g. A voltage instead of an earth)?
  11. Wolfgang72
    Wolfgang72 Rookie
    Jul 12, 2019
    45
    Munich, Germany
    Wolfgang Schmidt
    #86 Wolfgang72, May 25, 2020
    You're right, Ian. There was no evidence that the software would be the bottle neck. But there also was none that it would be anything else.
    Moreover I had some indications pointing at the software. According to Ferraris development style described above, the hardware should be (mainly) the same between F355 and F360. Plus the shift times for F360 were slow in the beginning but were improved in the CS only by changing the software. Plus the TCU internally uses a slow cycle time for processing (as mentioned before). Plus I had a talk to an hydraulics engineer who explained me that it's likely not about low pressure level or slow solenoids (as mentioned before, too).
    Still no evidence, yes. But enough for me to give it a try.
    I think the missing part was coming from the engine ECU. There is a lot more stuff going on on the CAN bus in the F360.
    Qavion likes this.
  12. Qavion
    14,615
    Ian Riddell
    Thanks, Wolfgang.
    If you knew the missing paramaters, do you know if there is a device which allows you to add information to the databus (outside the Motronics ECU)? Is there such a thing as databus "splice"?
  13. Wolfgang72
    Wolfgang72 Rookie
    Jul 12, 2019
    45
    Munich, Germany
    Wolfgang Schmidt
    Yes. You can easily add another note to send new messages. It is also possible to manipulate existing messages (which would be necessary here) by using a gateway.
    But that's not the difficulty. Instead it is:
    - The F360 shares information on the CAN bus, which simply is not available in the F355. Remember that the F360 has E-Gas and so on.
    - The meaning of the messages is unknown. Demanded torque, current torque, wheel speeds, engine speed, engine temperature, various states (brake pedal, switches, ignition key and so on)... I suppose all that is available on the CAN and considered by the TCU. But you don't know in which message and in which data byte it is encoded.
    I tried to reverse engineer that from the code. E.g. I found out that ID 0x1F0 contains the wheel speeds. But I didn't come far. You would need at least a CAN trace of a known driving scenario (hard acceleration, cruising, ...) with a known vehicle state (driving mode, brake pedal status, ...) to get any further.
    Qavion likes this.
  14. Wolfgang72
    Wolfgang72 Rookie
    Jul 12, 2019
    45
    Munich, Germany
    Wolfgang Schmidt
    #89 Wolfgang72, Jul 21, 2020
    Part 10 of Hacking the F1 TCU
    By the way, while I was searching for information on the F360 TCU I suddenly came across a chinese patent. It dates from January 2008 and describes many solutions available in the F360 TCU. Most of them match down to the last detail of it! E.g. the electronic devices listed there are the very same, schematics are identical and so on! The author of the patent is a chinese company. Maybe it is related to the Chery QQ, which was already discovered here in FChat? If you like, search for patent CN101230913.
    Of course automated manual transmissions (AMT) are not invented by Ferrari or Fiat on the other hand. They exist for a long time. However it was Magneti Matelli who launched the market in the mid to late 90s and made them popular for passenger cars. The idea is simple: Take a conventional manual transmission and replace all manual actuations with a hydraulic. That's it. The target was to close the gap between automatic transmissions with torque converter (comfortable, but heavy, expensive and inefficient) on the one side and manual transmissions (lightweight, inexpensive and sportive, but uncomfortable) on the other.
    Magneti Marelli called its system Selespeed. Alfa Romeo also exactly used this name for their cars. Other car makers called it Cambiocorsa, E-Gear, SMG II, Duoselect or, well, F1. But whatever they called it, the basis always was the Selespeed system from Magneti Marelli.
    The Selespeed always works the same and usually is just an add-on to an already existing manual transmission: A gear actuator replaces the gearshift lever and will select and engage gears. A clutch actuator replaces the clutch cylinders and will control the clutch position.
    Above picture represents the gear actuator of the 355F1. Five solenoids exist, EV1 to EV5. They modulate a hydraulic pressure which is translated by the gear actuator into movement of the control arm in the desired direction. For example, a shift from gear 4 to 5 first turns on EV1/2 until gear 4 disengages. Then it activates EV4 until the control arm has reached the shift track for gear 5. Next it activates EV1 until gear 5 engages. Similar to a manual transmission an engaged gear is self-locking, so finally all EVs are deactivated. (Not shown is the EV0, which operates the clutch - this should be self-explanatory.)
    Unfortunately most advantages of the AMT (lightweight, efficient) turned out to be irrelevant for most driving situations. Moreover most drivers didn't make any difference between AMT and normal automatic transmission. Due to both they perceived the AMT just as a slow and rather uncomfortable, but normal automatic transmission. A few years later the dual clutch transmissions entered the market and replaced the mentioned type (i.e. add-on type) of AMTs.
    brogenville, taz355, 601 and 2 others like this.
  15. Wolfgang72
    Wolfgang72 Rookie
    Jul 12, 2019
    45
    Munich, Germany
    Wolfgang Schmidt
    Part 11 of Hacking the F1 TCU
    Spending much time with the program code I became more and more familiar with it. I made good progress and finally reached a point where I had all basic parts together. I knew how the shift request is generated, the gear positions are detected, the solenoids for clutch and control arm are driven and so on. However I could not bring it all together. I missed the big picture. I knew there must be a master algorithm that controls shifting procedure - but I couldn't locate it.
    I got stuck. Once again I needed a new impulse, a new look at the things! I decided to put theory aside and try it with trial and error. To some this might sound unprofessional, but I think it's not. Many things were discovered by accident (Penicillin, X-Rays, Super Glue, Viagra... you name it).
    Now I would have loved to simply jump into my 355F1 and trace the software while trying some stuff. Unfortunately there was none in my garage and the only 355F1 I knew of was that of my client. But I neither could nor wanted to ask him. So testing in an 355F1 was not possible. But maybe this was also not necessary. Maybe it would be sufficient if I built a component test bench and run my tests there! This way I would not need a whole car, but only an AMT. That is Power Unit, Control Arm, Clutch Actuator and some miscellaneous parts. With all that I could see how the unit works during operation as well!
    Searching for the parts, I soon noticed that they are poorly available and incredibly expensive. For example, the Power Unit is no longer available at Ferrari. In a way that's a good thing, because they ask incredible €20,000 for it! Even a used one is still half of that though.
    Last time I explained that all Selespeed AMT are very similar. So I extended my search and included the F360. And finally AMTs of other car manufacturers as well. After a while I came across a fascinating unit that Alfa Romeo used in their 156. It integrates all items in a single block! That means the Power Unit and all Actuators are in the same housing including the respective hydraulic lines. Only the hydraulic pump and the reservoir are kept seperately (likely to improve NVH characteristics). Due to that the block is very compact. That was the perfect choice for my needs!
    I bought such a unit and mounted it on a frame. This is how it looks like:
    Next I modified the wiring harness so I could connect it to the TCU and my HiL. Then I powered everything up. From the beginning it worked... not at all! I can't remember what exactly was wrong. But I remember that I found a lot of "bugs" in my HiL and in my Reverse Engineering! So my test bench was already helping me before it even worked.
    I put everything straight and tried it out again. Below is a video of one of my first functional tests, where I cycle through the gears: N -> 1 -> 2 -> N.
    In order to carry out a shift, the TCU needs plausible values. This is especially true for the various speed values. If the speeds of gearbox input, clutch and gearbox output don't match, the TCU does nothing except set a DTC. To get them plausible, I had to write a simulation that copies the vehicle behavior as realistically as possible. I must admit that I first tried it myself. But soon I gave up. It's complex to design a system with three inertia (engine, gearbox, vehicle) that are connected by two independant clutches (regular clutch, synchronizer discs) and varying gear ratios. Fortunately, one of my employees graduated in physics. He wrote the simulation model for me. I think it's pretty good (though not perfect).
    Now I can watch how the TCU actuates the clutch and shifts the gears in reality. The following video shows, how I power everything up, turn on ignition and virtually start the engine. If you pay attention to the clutch actuator (on the right), you can see how it seeks PIS. Then I request first gear and the control arm turns into position for odd gears. Next I accelerate until engine RPM hits the limiter. After a short time an automatic upshift into second gear occurs. (Which, frankly, surprises me, because in manual mode a sports car should hold the gear.)
    After all this component test bench was a great decision. With it I left my deadlock behind me and I was able to try out many new things. Besides, it's fun to play with. Now all I'm missing is a real 355F1 ;-)
    tgaspl17, 601, brogenville and 6 others like this.
  16. brogenville
    2,324
    Robin
    What a cool little thing to build! What’s the insight you gain then for how the system can be improved then?
  17. Wolfgang72
    Wolfgang72 Rookie
    Jul 12, 2019
    45
    Munich, Germany
    Wolfgang Schmidt
    #92 Wolfgang72, Jan 8, 2021
    Back then I was still at a stage where I tried to figure out how the Software works. With the test bench I finally was able to see what it does in reality.
    Take the gear engagement for example. Don't think of it as simply driving the right solenoid until the gear is engaged. Instead it's way more complicated. There is a basic current applied first. Next there is an offset. This offset is gradually increased over time (and depending on travel). Then there is a hold time. And if the gear did still not engage, then finally an overdrive current is let out. But that's not all. The entire process is synchronized with the gear selection and starts a bit in advance to preload the mechanic. And of course there also is the clutch control running in parallel. That's what makes it complex.
    You cannot simulate this "orchestra" on a HiL and you will not figure out how it works by sitting at your desk. It's too complex. That's why I built the test bench.
    Again, back then I was not yet aiming on any improvements. Although this was (and still is) my target, the first step was to understand how everything works. Yes, all this is very time consuming with little progress in the beginning. But if improving shift times is possible, then this is the approach that will definitely work and will bring the best results!
  18. brogenville
    2,324
    Robin
    My feels on the F1 systems is that focusing on speed of the gear actuation is a bit of a misnomer. They're already slotting gears faster than a human being, but the perception is that its slower. I feel this is down to the clutch actuation speed and smoothness. If this could be refined, then the subjective experience would be improved.
  19. brogenville
    2,324
    Robin
    Wolfgang, I was looking at this Maserati training academy document yesterday on advanced electronics and your work came to mind. There is a detailed section on the workings of the F1 system, and importantly for you, a summary of the changes they made to each new generation to improve performance. There are some hardware changes here and there, but the main part is on how they overlapped various parts of the shifting process to speed things up. Definitely worth a read for you if you’ve not seen it.
    (The first part is on the engine control systems; the latter half on the marelli gearbox controls)
    https://pdfslide.net/documents/advanced-electronics-1-engine-and-powertrain.html
    taz355, Wolfgang72 and Skippr1999 like this.
  20. poz235
    poz235 Rookie
    Jan 4, 2012
    37
    West Bloomfield, MI
    Zach
    I shift from 1st or 2nd to 6th all the time by simply going into neutral and then hitting the upshift paddle, which will put the car in the highest gear possible without stalling. The computer will not let you select a gear that will stall the engine, either by going into neutral and selection from there or by winding thru the gears. If you're wondering why I upshift like I do it's to minimize the amount of times the clutch is used to help prevent wear, I need a new one (and possibly a flywheel) but can't afford the dealer's rates to set the PIS - the only real thing preventing people from being able to go anywhere for a simple clutch replacement. I found this thread and I have to say that it would be amazing if this project led to software that would allow for normal people to be less reliant on dealers to perform such functions. Even more remarkable would be for Wolfgang to rebuild TCU's as when the inside of mine caught fire in 2015 I literally got the last one Ferrari. It would be beyond wonderful if someone breaks the stranglehold Ferrari has on these parts and thus lower the cost of maintaining and repairing our beloved 355's.
    tgaspl17 and brogenville like this.
  21. poz235
    poz235 Rookie
    Jan 4, 2012
    37
    West Bloomfield, MI
    Zach
    The F1's are programmed to automatically upshift at the redline in normal mode no matter if you're in manual mode or not; it will, however, hold the gear in sport mode.
    tgaspl17 and ferrariformulauno like this.
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Hi Wolfgang
    I just thought of something you might be able to change, that some of us guys might like, now that it seems your understanding of the system is likely unprecedented on the planet.
    I was driving the car the other day and it is a bit disappointing that Ferrari would limit the downshift in first gear. I would like to see either in sport mode only that we could downshift to first when ever we want.
    That’s my wish list. I know myself this would be worth some money how much would have to be up to you I guess.
    cheers and if I have not said it before I love this thread.
    Grant
  23. Wolfgang72
    Wolfgang72 Rookie
    Jul 12, 2019
    45
    Munich, Germany
    Wolfgang Schmidt
    Whenever you request a new gear, your TCU estimates the new clutch speed after engagement. If it exceeds the maximum speed allowed, your shift request is rejected.
    There are two tables holding the maximum speed allowed, one for "low grip" active and one for inactive. "Low grip" active is very conservative, as you might guess. For "low grip" inactive the maximum speed allowed is (nearly) redline for all target gears though. That is you can always perform a downshift as long as this won't over-rev your engine.
    But as you have noticed, the one and only exception here is gear 1! For gear 1 the maximum speed is 6000 rpm. So whenever the clutch speed in target gear would exceed 6000 rpm, your downshift is rejected. I assume they did that for driveability matters (comfort, traction etc.).
    This restriction can be removed of course. The only trouble is: if I'd build a customized software for you, you still won't be able to flash it to your TCU.
    Maybe there will be a programing adapter some day... let's see!
    Wolfgang
    taz355, Qavion and brogenville like this.
  24. Skippr1999
    Skippr1999 F1 Rookie
    4,572
    Wolfgang,
    How is this project going ? Is the original goal still alive ?
  25. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    IoI, I forgot all about this thread. Where are at Mr. Wolfgang72?
    If memory serve me correct, you are trying to increase the electronic shift speed of the F1 neglecting the mechanical shift ability.
