Had the car for a few days, let the squeaking begin! Help! | FerrariChat
Discussion in '308/328' started by chrisbinsb, Dec 20, 2011.
  1. chrisbinsb
    chrisbinsb F1 Rookie
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    So I've had my new 308 since Saturday so I think it's time to start neurotically worrying about every noise I hear. Help put my mind at ease (or instill great fear?) Here's what I've noticed, two noises:
    1. When engine rpm is slow, like coasting down a hill so engine noise is relatively low, I hear what sounds like a flock of chirping birds coming from the front end (could be the back end too but it would drowned out by engine noise) - lots of little squeaks from both sides. If I had to guess, I would say it was suspension, shocks, springs, something like that but I'm still mechanically too illiterate to know, any ideas?
    2. The second noise is a sort of squeak/squeal that I hear when pressing on the gas. Holding my foot off the gas, all I hear is a nice burbling noise, when I press gently on the gas, there is a slight squeaking/squealing noise. It seems to go away when I press harder on the gas, but it may just be drowned out by the increased engine noise. I noticed it when I first drove the car, but after a lot more driving the last few days. it seems a little louder. (of course, I could just be more nervous now that I actually own the car....) Maybe noise coming from a belt?
    All help or suggestions appreciated!
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    There are many noises that come from these cars. It will be much more helpful for those here if we knew the year of your car and perhaps if you had the information on the last time belts and bearings were replaced etc. This will help narrow down the expected noises from your car vs unexpected. For example a frequency valve will chirp in a changing pattern like you mention but isn't present on all model years.
  3. barnyard
    barnyard Karting
    Aug 25, 2009
    61
    Each model is different,and 308 sound like no other,in fact 308 make lots of crazy noise,thats why the radio is only useful when your washing it,your car is fine,enjoy,dont worry.
  4. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Should have realized it might just help to know car I'm talking about! It's an '84 308 QV. Belts were just done, not sure about bearings, I'll have to check. Did a ppi so there's nothing in obvious need of replacement.
  5. jrinehart
    jrinehart Formula Junior
    Jan 30, 2009
    578
    Chambersburg, PA
    John Rinehart
    The noise when just pushing on gas then disappears may be either vacuum leak or just air flowing through throttle body. I had same sound after my head rebuild and gasket replace and the mechanic stated it was coming from the increased air moving over the throttle body.
    To check just move throttle manually at the place where the cable attatches to the throttle body and listen if the noise is coming from that area.
    $2 dollar ear plugs will eliminate the noise although not the worry.
  6. fast eddy
    fast eddy Formula Junior
    Apr 8, 2010
    282
    Utah
    Ed Davenport
    Be sure to check fan belts for tightness, and general condition. The alternator/water pump belt (behind passenger rear wheel well) is very thin, and any slipping (squeeling sound like you describe) will end in a disintegrated belt in very short order, followed by overheating and no battary charging. Tighten belts to spec imeadiatly! It's no fun to be stranded out on the road as I have learned by experience!
  7. Jdubbya
    Jdubbya The $10 Trillion Man
    42,510
    PNW
    If the chirping is coming from the front it could be the suspension squeaking. Does it do it when you are going over bumps or is it more steady.
    One common source for the chirping sound is the exhaust. It's the perforated screen inside that seems to make the noise. There are some threads here somewhere showing how to make a simple insert to stop that.
    I wouldn't worry too much about any of the noises though. Get to know then and eventually you will figure out what they are and whether they need to be fixed or not!!
    Enjoy driving it!!
  8. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Does the front end have urethane bushings? They tend to creak and groan over big bumps.
  9. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    That could be coming from the throttle pedal assembly itself. It's an elaborately-engineered piece that utilises four needle bearings and two spherical bearings (on a linkage rod from the pedal to the cable bell-crank). It could have dried-up grease and/or seized bearings and that could be causing that particular squeak.
  10. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    i would be glad to take your 308 for a good hard ride and give you my impressions :)
  11. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,775
    Cerritos, CA.
    Welcome Chris, what's the serial number of your car?
  12. mwr4440
    57,853
    Bavaria, The 'Other' Germany
    Mark W.R.
    ANY unusual noises from an engine bay, especially squeeking, are cause for concern.
    FIND Um;
    FIX Um;
    ONLY THEN ......
    Forget about them.
  13. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    You could always try shutting off the engine on a slope while in motion to hear the front squeeks better. CAUTION: power brakes will become very ineffect so be ready to restart and do in a safe place. Have you tried pushing on the throttle with the engine off to see if the throttle squeek is the assembly or the engine?
  14. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I have done this myself and was amazed at how little noise the car itself made. However, there were a few strange sounds that I don't think I will ever be able to localize and I refuse to obsess about. Of course I will now have to do it again since this thread has reminded me.
  15. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Since everyone is taking guesses here, I guess I'll jump in and take a few guesses also.
    Front end: If the squeak is rythmic, that is, as the car rolls, its a constant "squeak, squeak, squeak, squeak......" it's probably a wheel bearing. If it only squeaks when you hit a bump, it might be a suspension bushing, shock, something like that. If it's a suspension bushing, you can probably make it squeak by pushing up and down on the fender (just be careful not to dent the fender). Wheel bearing squeak will likely change a bit with speed.
    If it's coming from the back, first figure out if it's happening at idle or when the car is standing still. If it happens when the car is idling, not moving, pop the rear bonnet and try to isolate it. It's probably coming from the passenger side (right side). If so, it is probably a bad bearing, or a belt issue (water pump, alternator and/or AC). A good way to figure out where it's coming from is to take a length of hose (I use an old 3 foot piece of garden hose), hold one end to your ear and use the other to probe around. You'll figure out pretty quickly where it's coming from.
    The prime suspects would be water pump bearing, alternator bearing or timing bearings. Could also possibly be the AC compressor. Timing belts don't squeal. Water pump, alternator or AC belts can. If its a belt squeal, be sure you have the correct size belts, that they are in good condition, and examine the pulleys. I had a problem with my alternator pulley causing a squeal, and I was throwing belts. Turned out the pulley was messed up and was chewing up belts, and the alternator needed to be rebuilt. If you see a lot of black dust all over the place down low, suspect a bad pulley, but be sure that you don't also have a bad bearing.
    Just a few thoughts.
  16. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    p.s. Probably common sense, but I'll mention it anyway -- if you are poking around with a length of hose or stethescope to find the squeak on a running engine, be careful not to get the hose caught in a moving belt or turning bearing. Not good for you or the car. Ask me how I know. Like my dad warned me, be careful where you stick your hose. LOL
  17. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Thanks everyone, for all the responses and ideas. I'm not driving the car today, but I'll start looking into the ideas as soon as I can. A couple of clarifications based on the questions above:
    The front squeaking is random rather than rythmic, but not tied to large bumps. The sense I get is that it's related to random road imprefections and slight movement of the suspension rather than larger movement. It really is like having a small flock of tiny birds chirping away. (maybe I'm being followed by them like in a disney movie?) I'll trying pushing down on the fender a little as suggested and see what happens. I can also try rolling down a hill, but will have to find a safe spot to do that.
    The rear squeal is not present when idling, only when pressing the gas after having my foot off it. It seems then to disappear as I press harder, but may just be drowned out by engine noise. My concern with this is that it seems louder than when I first drove the car. Could it be moisture related? Prior to this it was only be driven after being taken from a warm garage and into the San Diego sun. Now I've been driving it at night and unfortunately it has to live outside under a cover instead of the nice garage it deserves :(
    The belts were all checked out for the PPI, so I would hope that's not an issue. I do find that the battery light stays on for a brief period (less than a minute) after starting up the car sometimes - would that indicate an issue with the alternator belt or is it normal?
    Thanks again, so much to learn.......
  18. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    50431, why do you ask?
  19. miketuason
    Feb 24, 2006
    15,775
    Cerritos, CA.
  20. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
  21. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    My first thought would be the alternator belt. Sounds like it might be slipping. It's kind of typical for it not to squeal at idle, and then start when you step on the gas and RPMs go up. Check the belt tensioner, make sure it didn't loosen up and that belt tension is correct. Even though someone looked at them during the PPI doesn't mean that it is tensioned correctly. Also, look for telltail signs of belt wear, like black dust near the crank pulley and the lower parts of the engine.
    The only way to really get in there is to put the rear end up on jackstands, remove the right rear wheel, and the wheel well liner to get access to the belts. It's not a big deal to get in there. Once you do, you can get a clear look at the belts, pulleys, etc., and get a better idea where the sound is coming from.
    p.s. Don't overtighten the alternator belt. The pulley is aluminum, and it is not a stock Bosch pulley. It's a custom piece specific to the 308/328 cars. I had to buy a new one from Ricambi America for my 328 as the old one deformed and was eating up the belts. So be careful when you tension it. If the belt is not fitting right or is showing any signs of wear, just buy a new one (and a spare).
  22. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    Do you ignore the holes in the bottom of your shoes as well ?
    As for the noises.
    1. You answered your own question.
    2. Tighten the AC belt.
    What did the PPI say about the bushings, suspension etc?
  23. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Had it out last night and pushed down on the fenders, but there was no noise. now I wondering if I'm just not hearing it correctly and the noise are all actually coming from the rear.....
    There's still two distinct items, the one when accelerating and the other that may be all the time, but I only hear it when the car is coasting with low engine noise.
    Hopefully this weekend, I'll have time to check out some of the suggestions here and maybe I can get together with somebody local who kows more than me about these things to get some input.
    I've really got two concerns, first that nothing is going to cause a mechanical problem and second, that the noise distracts from the enjoyment of the car (particularly when I keep wondering what on earth it is).
  24. rob
    rob F1 Rookie
    May 22, 2002
    4,261
    Vt
    One thing that you should get in the habit of doing when you have an older car is to check the front wheels for play. Make sure the steering wheel is locked and grab the front tire at nine and three and try to move it back and forth and grab on the top in the back of the tire and try to move it towards you and see if there is play basically you are checking for any free play and there shouldn't be any and if there is you should have it checked out sooner rather than later.
  25. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    PPI noted some minor cracking in the bushings that within what it typical and normal, ball joints, all OK, tie rods, shocks and control arm bushings, control arms & forks recently replaced, On the sway bar, the right main clamp had slight deformation which has caused some slight cracking of the bushing.
    In discussing this with the guy that did the PPI, everything was within normal expectations but I'll be planning on repairing/replacing some of these items in the course of other work over time.
    Not sure if that helps, but there it is.
