Had this happen on a drive in my 348 today..how bad is it? | Page 2 | FerrariChat
Discussion in '348/355' started by Falcon Wing, Jul 16, 2013.
  1. larrybgreen
    larrybgreen Karting
    Mar 16, 2012
    84
    New south wales
    So guys a serious question my speedo also reads 20 KPH when parked and tacho a 1000, is there a fix on both of these instruments. Is it common for this to happen? ps 94,000kms on my 1991 348ts in Sydney Australia. regards larry
  2. Nosevi
    Nosevi Formula 3
    Jul 8, 2011
    1,990
    Lincoln
    Pete
    Funny, it's happened to some Ferraris numerous times ;)
    The 'fix' would be to take out the little pin the needle sits on at this point on the dial :) It's deliberate, the instruments don't read accurately below this point so a small pin is in the dial so the needle doesn't fall below it and give a false reading. Have a close look diagonally up and left from the zero on Falcon's first pic. Just check but the numbers should be just below what you've said.
    And Falcon, past exactly the same mark this weekend on a drive to a Ferrari meet - our cars are practically twins :)
  3. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,223
    Huntsville, AL., USA
    Andrew
    I wonder if it's genuinely due to inaccuracy below 10mph, or whether it is merely that the needle would then start to obscure the first digit on the trip mileage if it pointed at 0mph. The latter sounds like a far more Italian automotive problem and solution. :)
    All the best,
    Andrew.
  4. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    LMAO
