Hand brack problem to week | FerrariChat
Discussion in '308/328' started by Alpo Marzoppi, Apr 15, 2012.
  1. Alpo Marzoppi
    Alpo Marzoppi Rookie
    May 3, 2010
    7
    Natal South Africa
    Alpo Marzoppi
    Please can some one tell me how to set
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,666
    South East
    Jimmie
    308 handbrakes are legendary for not working - I'm sure there are many threads here with advice for fixes that may or may not last - try a search on '308 handbrake'
  3. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    I'm going to try to get mine to work as well, but be careful that, even when released, the brake levers on the rear calipers themselves are not continuing to apply pressure. I have read how even though the lever is all the way down in the cockpit, the mechanism can still stick with enough tension on the rear pads to cause severe rotor and pad wear.....especially on the inside, where it's not as visible. In other words, they do not always release well :)
    Alpo...it's fairly common for the hand brake pulleys and cables in the rear to have some corrosion. I'd start by putting the rear on ramps and looking over the mechanism back there. The pulley system is bolted to the rearmost crossmember. If you have the steel plate in place back there, simply remove it. You'll then have a good look at the cabling.
  4. airdelroy
    airdelroy Formula Junior
    May 10, 2007
    420
    Austin, TX
    Aaron Richardson
    Maybe we could fashing a brick on a string and attach it to the handbrake lever. That would work better. :D
    I spent some time on mine a few years ago and got it to work OK. I think the system needs to be redesigned to make it work great.
    Aaron
  5. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    I use two pieces of 4"x4" pine, each about 1.5 feet long. Back the car gently down the drive until it comes to a stop. If you live in a ritzy neighborhood you might have to go to oak or mahagony
  6. noblesteed
    noblesteed Formula Junior
    Sep 9, 2011
    509
    Oklahoma
    Brantley
    Haha. Funny! I agree. And, I've also learned that the handbrake on the 308 is completely useless. Not worth the trouble of fixing in my opinion.
  7. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,847
    Edwardsville, IL
    Jeff Kennedy
    Alternative is a big rock.
    eff
  8. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I simply cut the end off a 4X4 to create a nice wedge and keep it in the boot.
  9. BigTex
    79,380
    Houston, Texas
    Bubba
    To the OP, carefully examine the cable system, making sure it has not broken or jumped a pulley.
    Then adjust for slack.
    That is usually why it's not working, unless you have a stuck/dirty caliper at the brake itself!
  10. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    Its a fine line in getting this set. So were between no enough and too much comes down to a half a turn of the turn buckle. I had to release mine to do the interior work, but will have to go back to the e-brake redesign project when its done.
  11. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #11 Crowndog, Apr 16, 2012
    Chairpilot did a whole R&R on the handbrake with pictures somewhere here and found that the rotating bracket in the rear that has the pulleys on it had been bent down through the years to the point that it couldn't pivot the entire way around as it should. One of the bolts hit the cross member. So, may want to check this out and see if the pivot plate thing is not hitting anything. Part #13 on the picture
  12. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Good idea, as that's a dodgy looking setup back there.
  13. 308 GTB
    308 GTB F1 World Champ
    11,722
    New Jersey
    Barry Wolinsky
    #13 308 GTB, Apr 16, 2012
  14. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Probably the same guy designed the 308 handbrake and window mechanism. Fortunately seems like they fired him by the time the 328 was designed :D
  15. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Rumor has it that his name might have been Rube Goldberg.
  16. Scudjockey
    Scudjockey Karting
    Aug 28, 2010
    81
    Suffolk, UK
    John Marshall
    I rebuilt my whole system when I did the car last year. Completely refurbished the pulleys and pivots and fitted a new cable kit from Superformance. Add in rebuilt callipers and new pads and discs and I expected it to work well. It doesn't. Looking at it carefully and thinking about it to optimise the adjustments I think the real problem with the design is that although the hydraulic system applies pressure to the pads on both sides of the disc, the handbrake lever only pushes on one side of the disc. Its never going to work properly.
  17. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Mine works perfectly. I just park on a flat surface and put it in first and set the handbrake. The car doesn't move. LOL
  18. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
    Mine are rebuilt but don't work worth a **** on a slope so solution..
    Wheel chocks!
  19. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    With no wind on a perfectly level surface mine works perfectly.
