Hand brake light | FerrariChat
Hand brake light
Discussion in 'Mondial' started by ltoth, Jun 2, 2016.
  1. ltoth
    ltoth Rookie
    Nov 20, 2008
    43
    heidelberg,ont.
    leslie toth
    After relasing the hand brake the handbrake light on the instrument panel stays on. The handbrake is definitaly released. Any suggestions ?
    Another question: this Saturday will be the Ferrari Club of America Concours in Ontario. Any of you guys know WHERE is this event will take place? No, I do not want to enter I just simply like to talk to fellow owners-shop talk.
  2. Alden
    Alden F1 Rookie
    3,635
    Central Florida
    You don't list a Mondial in your profile or your post, a bit more info about which Mondial you have would help us help you.
    Alden
  3. ltoth
    ltoth Rookie
    Nov 20, 2008
    43
    heidelberg,ont.
    leslie toth
    In addition to the 78 308 GTS I also have a 1987 Quatrovalvole Cabriolet. I believe last year I had the same problem -I drive these cars only in the summer-and after pulling and releasing the handbrake a few time the light went off, but I would like to fix it so next year I wont have this problem again. Where should I look?
  4. drbruno
    drbruno Formula Junior
    751
    Toronto, ON
    Dr. Bruno L. Venditt
    The Ferrari of North America Concours is at Vaughan Estates in Toronto this Sunday.
  5. ltoth
    ltoth Rookie
    Nov 20, 2008
    43
    heidelberg,ont.
    leslie toth
    drbruno: thank you !
  6. billh1963
    billh1963 Formula Junior
    Apr 28, 2004
    863
    Mid-state, South Carolina
    Bill H
    I had the same problem. Pull the cover off the handbrake (one or two screws). At the back of the handbrake you will see an easily accessed switch (with a wire coming off it). Adjust the height of the switch so that the light comes on when the handle is pulled and goes off when released. It's really very easy.
  7. ltoth
    ltoth Rookie
    Nov 20, 2008
    43
    heidelberg,ont.
    leslie toth
    Thanx billh will give it a try!
  8. dipstick1
    dipstick1 Formula Junior
    May 24, 2004
    312
    Connecticut
    Peter Lombardo
    If the Switch is broken it is Part # 114318 and is available- Ricambi has is for I think $28
  9. ltoth
    ltoth Rookie
    Nov 20, 2008
    43
    heidelberg,ont.
    leslie toth
    Hi guys ! The hand brake light problem is taken care of: first you remove the stainless steel trim part , next the leather covered panel, next the handbrake cover. The light switch is in a bracket held to the body with one 6 mm nut, remove the nut, lift the switch and place two 6 mm fender washers between the bracket and the body, so now the switch sits about 2mm higher than before and voila ; no more hand brake light issue. Oh, you wil need an 8 mm wrench to remove the nut.
