Hans Device | FerrariChat
Hans Device
Discussion in 'Tracking & Driver Education' started by jcurry, Nov 4, 2020.
  1. jcurry
    24,153
    In the past
    Jim
    Got a new track toy, a 951 that is full race configured (used in PCA club racing early 2000's) with roll bar and full harness. PCA HPDE requires a Hans if using harnesses. So my question is which Hans. My initial thought is the basic Hans III. This then leads to the follow up questions of angle (20 or 30 deg), size (med/lrg), attachment (post anchor/quick click), and certification (FIA/SFI/dual). Help please.
    obligatory pic @ PIR (Portland) a couple wks ago.
    308 GTB likes this.
  2. LBBP
    LBBP Formula Junior
    I use a Schroth SHR Flex which has built in flex adjustment for different seating angles. You will need to have Hans specific belts (2") for the shoulder area. Mine is SFI 38.1 rated and is a medium, under 16" neck with the fixed post attachment.
    jcurry likes this.
  3. greg512tr
    greg512tr Formula Junior
    Feb 19, 2002
    995
    Dallas TX
    Greg B
    I highly recommend looking into the Simpson Hybrid Pro. The advantage is it can be used with roll bar/full harness and also with traditional 3 point seat belts. I use mine in PCA DE events with my stock 1984 Carrera and also with the Ferrari Challenge car.
  4. fatbillybob
    Aug 10, 2002
    29,443
    socal
    HANS is the 800lb gorilla and all the pro data is with HANS. They are the ones with black box 100+G survivable crashes IMO there is no reason to own anything else. Buy the HANS with FIA certification. It then does not expire. If you buy the same thing but cheaper with SFI cert you have to recertify in 2 years at some fee. FIA's never expire. You want the upright seating position HANS which I think is 20 degrees. Just ask your supplier or get one from good source like HMS mortorsports maybe pegasus motorsports, winding road,...
    308 GTB, Nuvolari and jcurry like this.
  5. LBBP
    LBBP Formula Junior
    38.1 certifications last for five years, not two. Even FIA recommends (check with your sanctioning body) the tethers be replaced and a new cert. sticker attached every five years, sooner if there is any visible signs of wear/abuse found at Tech.
  6. willwork04
    willwork04 F1 Rookie
    4,347
    Echo fatbillybob. This is NOT a place to go cheap. I use HANS. You need 20 degree as you are upright in a car and not low slung in a formula car. I have the quick click and prefer that as I can easily separate from the helmet.
    Davesvt2000 and jcurry like this.
  7. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,218
    France
    HANS, FIA-certified, 20 degree as stated.
    Then you look for a "standard" or lighter model, but this is more for comfort. I "race" with a relatively heavy one and I do not find it an issue at my level.
    jcurry likes this.
  8. jcurry
    24,153
    In the past
    Jim
    Thanks. I like the appeal of the hybrid, and have seen them being used at Porsche DE events, but honestly don't think I'll be tracking the 360 much, or at all, anymore.
  9. jcurry
    24,153
    In the past
    Jim
    Like this as well, with some interesting features, but my harnesses are 3inch.
  10. LBBP
    LBBP Formula Junior
    Your three inch belts will work, mine are three inch with the exception of the top of the shoulders where the belts pass between the 'horns" of the Hans device. If there is a race shop near you I would see if you can try several different types of Hans devices, you may find you prefer one completely different than whats been discussed.
    srslusso likes this.
  11. Challenge64
    Challenge64 F1 Veteran
    6,367
    Ron
    I use the Stilo Zero GT with the matching Stilo HANS Zero at 30 degrees.
  12. mdrums
    mdrums F1 Rookie
    3,770
    Tampa FL
    SECRET likes this.
  13. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,384
    Himalayas
    I use HANS Pro Ultra Lite and recommend it
  14. Rosso328
    Rosso328 F1 Veteran
    7,371
    Central FL
    Paul
    Echoing those that suggested the Simpson Hybrid. I spent a lot of time looking at test results and certifications to be sure it wasn’t “cheaping out” on an inferior product.
    Ultimately, it fits my cars better - the Lotus seats aren’t really HANS friendly, forcing my head forward even with every angle I tried - can be used with either harness or three point belts, fits other people’s cars too - I enjoy the odd right seat ride with more experienced drivers - and over the last few years I see more and more pros across multiple racing series going for it.
  15. ewright
    ewright Formula Junior
    Nov 17, 2003
    612
    The HANS Pro Ultra Lite recently saved my life in a high speed impact. I can't speak to other restraints, but I would highly recommend the HANS device. I refuse to get on track without one.
  16. SECRET
    SECRET Formula 3
    1,050
    Maranello, Italy
    Ferrari Tifosi
    I use the Simpson Hybrid S as well. Fantastic system
  17. Cajun
    Cajun Formula 3
    Mar 20, 2004
    1,618
    Da BY-U
    MJG
    Nice looking car! Looks a lot like mine. I run at PIR, Hopefully I will see you around next season.
  18. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Nice Type 951, Jim. I bought my 1987 951 new in August 1987. I've added some Lindsey racing stuff to make it go better. I've never tracked my 951 and it's my daily driver with ~175,000 miles...
    I use a HANS Adjustable Series device when I track my F355 Challenge...
    It can be set up to suit any seating angle from 10 to 40 degrees...
    The tall epaulets help keep the shoulder harness straps secure. It's SFI 38.1 and FIA Approved.
    A medium size will fit most drivers.
    Barry
  19. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    533
    Pacific Northwest, USA
    Dave W
    Realize this is an older thread, but if you haven't made a decision yet jcurry, I'll add another vote for the HANS adjustable. Not only will it come in handy if you see yourself in a Formula car or Sports Racer in the future, but it also allows you to dial-in the fit of the HANS to your particular seat/helmet/car environment.
    308 GTB likes this.
  20. jcurry
    24,153
    In the past
    Jim
    Too late.:D Got the Pro Ultra Lite! Haven't been in the car yet, which is in the shop getting a new head gasket.
  21. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    647
    Austin, TX
    If you already have 3" belts, a HANS with the high ridges on the sides will work fine. I got one before the varying-width belts (2" at the shoulder for the hans, 3" at chest to spread the load) became common. My HANS came with both FIA and SFI labels and I simply removed the SFI one, but I'll be getting mine inspected and the straps replaced anyway since it's been a few years.
  22. jcurry
    24,153
    In the past
    Jim
    Yeah, first time out with the HANS I didn't get the belts located properly and ended up with a nice bruise on the inside of my arm when the belt shifted off the HANS. Second time I was more careful and they stayed within the ridge. Am looking at getting the varying-width belts just to make it more secure.
    Dogdish likes this.
  23. Zalfor
    Zalfor Karting
    Mar 31, 2013
    54
    Chicago
    any of these restraint systems are good. the more expensive models dont give you more safety, but they're lighter, fit better, etc. just get one that fits you and doesn't fall off the belts. hans saved me from injury multiple times.
