Hard brake pedal | FerrariChat
Hard brake pedal
Discussion in '360/430' started by [email protected], Mar 3, 2015.
  1. rhall@mtuinc.com
    Jan 2, 2014
    16
    I bought my 2004 360 Spyder over a year ago and have had great luck except recently I've noticed that the brake pedal has no give. It still works but the pedal will go so far and just become hard with no give what so ever. Anyone got any idea what's going on?
  2. Rifledriver
    37,108
    Could be a vacuum leak, bad vacuum check valve(s) or a bad booster.
    I would expect more symptoms than you are describing.
  3. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,587
    I know this is an old thread, after a search, no other threads on topic.
    my pedal is going hard intermittently, braking still works, but sometime leg pressure needs to go way up, what would cause this??
  4. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Same advice he gave 7 years ago. Vacuum leak, check valve, or vacuum booster.
