hard gear changes on a 88 testarossa | FerrariChat
Discussion in 'Technical Q&A' started by portogts, Mar 9, 2009.
  1. portogts
    portogts Formula 3
    Owner Project Master
    Aug 31, 2008
    2,344
    Maia-Portugal
    Vitor Sousa
    Hello !!
    I need some help here , please ,
    the gears on my testarossa are dificult to engage even when hot , specially first gear.
    First is only good when coming to a stop very slowly will it engage OK.
    Second will engage OK when hot
    No crunch or clutch slip.
    With the help of Steve Magnusson there came the idea of gear linkage alignmente or clutch problems.
    I will start with the alignment , can someone help me on this process and give me some ideas how to do it???
    Please
    Thank you very much
    Vitor
  2. Steve Magnusson
    26,779
    #2 Steve Magnusson, Mar 9, 2009
    Vitor -- I forgot to ask you (and I realize that you might not have anything to compare it to, but) -- when the engine is "off" and the clutch pedal is depressed, can you select the different gears much more easily, or are they equally as "difficult" as when the engine is running?
  3. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    If so this would point to a clutch release problem. Possibly air in system. Sometimes, if you sit in the car whilst running, push in the clutch and select first gear while watching some 'point' outside of the car. Sometimes you will detect a slight movement of the car relative to the outside road/wall for example, indicating a poor clutch release point. (or wrongly installed/shimmed clutch pack)
  4. portogts
    portogts Formula 3
    Aug 31, 2008
    2,344
    Maia-Portugal
    Vitor Sousa
    When the engine is"off" the gears are a bit easier to select. but not very smooth.
    I´ve driven a 90 testarossa and it was much easier to change gears.
    I tought on bleed the system first , the try the alignment of the linkage and the the take out the clutch.
    What do you think?
  5. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Just a thought, but I had James Patterson at Norwoods replace the nose bushing where the shift mechanism goes into the box.
    This was an enormous improvement; mine had gotten so bad that 2nd was not available at all and 3rd barely there.
    It fixed an oil leak, too.
  6. portogts
    portogts Formula 3
    Aug 31, 2008
    2,344
    Maia-Portugal
    Vitor Sousa
    Hi ,
    This was made with gearbox in place or wth the gearbox out?
  7. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    #7 Mr.Chairman, Mar 9, 2009
    I think your on the right track. I would bleed system first (it is the easiest to do), then check your linkage and bushings, then look into the clutch. Two things in the clutch that will cause this symptom. I bad throw bearing or your pressure plate (broken teeth or just spent). Are you sure that during aggressive acceleration the clutch is not slipping. My car was doing the same thing but the 1 and 2nd engagement was very tough. Turned out that my clutch and thro bearing were fried.. big time.. Has the car been sitting, how old is your clutch, bearing, etc..
    Robbie
  8. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    He was able to do it with the engine and gearbox in the car. I think a couple of hours or so.
  9. furmano
    furmano Three Time F1 World Champ
    Jul 22, 2004
    32,215
    Colorado
    Furman
    When was the last time the transmission oil was changed and what brand of oil was used?
    -F
  10. portogts
    portogts Formula 3
    Aug 31, 2008
    2,344
    Maia-Portugal
    Vitor Sousa
    #10 portogts, Mar 9, 2009
    i bought the car in July 2008 and that service was made in december 2007 , i guess it was Shell , not sure.
    By the way and since i will be working on that area , can anyone tell me what would be the best transmission oil to have on my car?
    Where i live temperature is not an issue (min: 8º C and max : 25-30º C)
  11. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Also, if you notice leakage from the seal where the shifter enters the trany, check the condition of the bushing in the knuckle. There is a rubber isolated bushing where the 6mm bolt connects the linkage. Probably not the cause of the hard shifting but it can effect the "quality" of the shifting. FWIW.
    Jeff Pintler
    89 348tb, 86tr
  12. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    When mine went, it just deteriorated to the point of crumbling apart. 2nd gear would spit the gearshift lever right back out in your hand when you engaged the clutch. Third was hard to shift into unless with a lot of force and slowly, and there was a lot of whining noise from the linkage.
    I got it over to Norwoods on the back streets before trying 4th and 5th.
  13. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    I use Royal Purple Max Gear 75/90. I have had great results.
    R
  14. Rifledriver
    37,089
    Has it ever been OK?
    A very large percentage of them never had the internal linkage adjusted well at the time of assembly because the factory procedure and their tooling for doing so was poorly thought out. I took the side plate off of many when they were new cars to correctly adjust it. When that is done, the external adjustment is done and a good gear oil is used it should shift quite slick.
    I have used most of the oils out there and when adjusted properly I think the Redline works the best.
    Do NOT use the Shell Ferrari uses or the Agip they used to use. It will shift well and kill the trans.
  15. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Brian, can you tell just by driving the car? - or do you have to pull the plate and look at or measure the internal linkage?
    I think Patterson both replaced the bushing and also adjusted everything - it is now just about the best shifting Ferrari I have ever driven.
    One more question, BTW - is there any way an owner can realistically check the trans oil level on one of these? Mine still leaks a little from the left side axle seal.
  16. portogts
    portogts Formula 3
    Aug 31, 2008
    2,344
    Maia-Portugal
    Vitor Sousa
    Hello everyone ,
    Thank you so much for all your opinions that for me are very importante.
    Today i started working on the car but had to stop.
    I will continue with bleeding the circuit tomorrrow evening and will tell you all what was the result.
    If no good result i will proceed with the gear linkage alignment and with what rifledriver sugested
    (I will need help on that one , please , rifledriver!!!!!)
    I will end up changing the transmission oil just in case .
    Once more thank you all .
    I´ll be giving news tomorrow ...
    All the best
  17. portogts
    portogts Formula 3
    Aug 31, 2008
    2,344
    Maia-Portugal
    Vitor Sousa
    the previous owner never told anything about that , but i always thought it wasn´t that slick , specially after driving another Testarossa.
  18. Rifledriver
    37,089
    You can tell by driving.
    You can make them shift like a Japanese car if you hand lap the syncros when you assemble them.
    The fill plug is not that hard to get to if the back is slightly raised.
  19. Rifledriver
    37,089
    Its not something I am going to be able to teach you over the internet except to say the internal mechanisim (selector forks) needs to exactly replicate the shape, alignment and spacing of the gate and the external adjustment needs to precisely align the shift lever with the shift selector inside the transmission.
  20. portogts
    portogts Formula 3
    Aug 31, 2008
    2,344
    Maia-Portugal
    Vitor Sousa
    Thanks , i will need this if i have to get to serious work on the car.
    What i wanted to ask is , this is made with engine and gearbox in place or out?
    Thank you
  21. RGigante
    RGigante F1 Rookie
    Nov 1, 2006
    2,874
    Portugal
    Would anyone have pictures like the ones i have for the 308/328? That would help a lot!
    Portogts, let me know if you need any help. I'm glad to give you a hand
  22. Rifledriver
    37,089
    TR and 308 internal adjustments are really quite a bit different in practice.
  23. furmano
    Jul 22, 2004
    32,215
    Colorado
    Furman
    #23 furmano, Mar 10, 2009
    Can you explain this a little further? I assumed good shifting was a sign that you weren't killing the tans.
    -F
  24. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    Had a similar problem with my tr. Did 2 things, added a gearbox additive cannot remember its name but I did post it on this site on a similar thread years ago. Second I serviced the slave cylinder seals can not remember if these are near the clutch pedal or in the gear box but once these two things were done it made a world of difference. The thing was the clutch needed replacing some 8 months later, nothing to do with the repairs just its end of life so it may be a combination of all 3.The tr in all that I have driven and all I have spoken to has always had a stiffer action than others when cold and 1st to second was always a bit ch.
  25. RGigante
    RGigante F1 Rookie
    Nov 1, 2006
    2,874
    Portugal
    That's the reason why I asked for any info, like pictures:)
    I have the WSM for the 308/328 but not for the TR. Anyone has a source or care to share one?
