hard gear changes on a 88 testarossa | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by portogts, Mar 9, 2009.
  1. Rifledriver
    37,288
    The Agip turns to water and does not lubricate when hot and the Shell is just never a good lubricant.
  2. portogts
    portogts Formula 3
    Owner Project Master
    Aug 31, 2008
    2,358
    Maia-Portugal
    Vitor Sousa
    Hello everyone!!!
    Today i checked the clutch circuit and bled it!!
    Nothing changed at all.
    So here are some conclusions :
    With the engine off , gears engage OK.
    With the engine running i press the clucth pedal , start to engage first gear , and i notice that the car
    moves a little forward.
    If i engage reverse the car moves slightly backwards...
    I think i will have problems with the clutch as some of you saied...
    Next thing to do i guess is to take the clutch out.
    One question :
    To remove the clutch housing do i need to take the three transfer gears off or can i take the housing complete without touching those gears?
    More to come on this adventure , possibly with photos but for now i will enjoy some days on my first trip to California with the family!!!
  3. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Sounds like a throw bearing and or clutch pressure plate.
    R
  4. drewprof
    drewprof Rookie
    Feb 5, 2009
    27
    Maryland
    Drew
    I second that!
  5. anthonyh
    anthonyh Rookie
    Oct 13, 2008
    29
    Please change the clutch plate and the pressure plate. The pressure plate is located on the top of the clutch plate.
  6. portogts
    portogts Formula 3
    Aug 31, 2008
    2,358
    Maia-Portugal
    Vitor Sousa
    Hi ,
    my next step will be taking out the clutch. But only in April!!! California First!!
    My only question is about the transfer gears...
    The clutch housing will come out with the gears or first take out the gears???
  7. Steve Magnusson
    26,932
    #32 Steve Magnusson, Mar 13, 2009
    They added a splined slip coupling on the input shaft to the gearbox so you don't have to take the trasfer gears apart -- but I don't if doing it that way requires more disassembly of the coachwork/bumper/exhaust behind the transfer gear case to have more clearance to slide the whole "pumpkin" further backwards.
  8. portogts
    portogts Formula 3
    Aug 31, 2008
    2,358
    Maia-Portugal
    Vitor Sousa
    Hi Steve ,
    Thank you very much !!
    I will take the exhaust , bumper out anyway to paint it so i think it will be ok to take the whole pumpkin out
  9. portogts
    portogts Formula 3
    Aug 31, 2008
    2,358
    Maia-Portugal
    Vitor Sousa
    Hello everyone!!!
    Just got back from sunny California!!!
    What a beautifull place...
    I took the clutch out and :
    --pressure plate looks normal
    --first disk is OK
    --intermediate plate and second disk not good , the use is not uniforme.
    I guess that means new clutch.
    Has anyone heard about ceramic or carbon clutches?
    Is that any good , reliable , costs?
    Thanks to you all
  10. lasvegascop
    lasvegascop Karting
    Apr 12, 2009
    222
    Las Vegas, NV
    "Ski"
    Just had a Kevlar clutch put in...works great!
  11. HBD
    HBD Rookie
    Nov 17, 2021
    25
    Orange County, CA
    SCT
    I’m experiencing nearly identical symptoms as the OP (I know this is an old thread). Clutch has very little miles on it. So I don’t think it’s that. It feels like a bushing in the shifter.
    car off clutch in or out it’s not smooth. First sometimes has to be forced pretty hard in. Car on clutch in. Same results. But slow deceleration goes into first totally smooth.
  12. Steve Magnusson
    26,932
    Doesn't that just mean that someone has recently mucked with everything related to the clutch, and it hasn't worked very well since ;). Seriously, I'd do some basic things first like review what brand/type gear oil was used, check the gear oil level, and ensure that the clutch circuit is properly bled. One functional test that you can try is with the car on a level surface (with room in front of it), 1st gear selected, clutch pedal depressed, brake pedal not pressed, and emergency brake off -- then crank the starter motor. If the coachwork lurches forward = clear sign that the clutch system is not disengaging well. Otherwise, things like ensuring the two rubber bushings in the shift rod assembly haven't degraded, and taking off the sidecover to see if the adjustment is, or isn't, good (as Brian previously posted) are the next (but more difficult) diagnostic steps. Good Hunting!
  13. HBD
    HBD Rookie
    Nov 17, 2021
    25
    Orange County, CA
    SCT
    Thank you sir!
  14. Steve Magnusson
    26,932
    No trouble -- easy enough to type some words on a keyboard ;). Please do let us know what eventually had to be done to get it sorted. When you say "very little miles", is it the original clutch that has never been molested at all, or was the clutch assembly recently replaced/refreshed?
  15. HBD
    HBD Rookie
    Nov 17, 2021
    25
    Orange County, CA
    SCT
    I’ll need to check exact records. But I believe it was changed about 2k miles ago during a major service in ‘17
    car has 11k miles on it (ive put on a little over 300 since I got it last week, I don’t let **** sit :) )
  16. Steve Magnusson
    26,932
    Good for you! I've also used my TR as a dry weather daily driver (even as my go to work commuting car when I was doing that), and have really enjoyed doing so.
    Needing a new clutch at only 9K miles seems a little suspicious (unless really abused) and may have been the wrong fix applied to the problem -- Brian's comments in post #14 about "Has it ever been OK?" and new TRs needing readjustment are a little ominous. Don't have anything else to add myself, but always interested to learn what the trouble was and how it gets resolved.
    HBD likes this.
  17. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,849
    Bologna
    I have used both Shell and Agip in my 91. It shifts well after the bushings in the linkage were replaced and the side cover removed to align the mechanism.
    Maybe neither Shell nor Agip were the best choice for the gearbox.
    So what IS the suggested oil?
  18. Steve Magnusson
    26,932
  19. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,849
    Bologna
    Thanks for the heads up. I always use GL5 on the TR. Unfortunately most brands mentioned in the thread are not available where I live. Will try to find 10 litres of Motul, if they carry it.
  20. HBD
    HBD Rookie
    Nov 17, 2021
    25
    Orange County, CA
    SCT
    Anyone happen to have anything that references the bushings in the shifter? It def feels like a bushing is binding or linkage is off. Clutch doesn’t appear to show any signs of slippage.
