Hard starting 308 | FerrariChat
Hard starting 308
Discussion in 'Technical Q&A' started by Ago, May 11, 2006.
  1. Ago
    Ago Rookie
    May 4, 2006
    23
    Kamloops BC Canada
    Agostino Pietramala
    I have a 81 308 gtsi Black,Great car ,but it is a little hard starting cold,takes about three tries no big deal.However after it has run for a while,and then sits for about 15 minutes it is very hard to start.I have to crank the motor over for a good minute before it fires up,and then it run a little rough for about 15 seconds,almost as it was flooded.When starting warm I need to hold the throttle peddle all the way down.Once it has started it idles very smooth at about 900 rpm.I had it looked at where I live and was told it is the warm up regulater,but that seems odd because the motor has been warmed up
  2. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    You need a full fuel pressure test and fuel system check. You should not need to touch the throttle (cold or warm) when starting an injected car.
    My WUR was the wrong Bosch part and it caused poor warm starts and poor warm idle. A replacement correct WUR solved both problems. This was determined after a fuel pressure test.
    There are lots of posts in the archives dealing with this exact issue- try a search for much more information.
    Good luck.
  3. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I think a bad accumulator would give those symptoms. It's purpose is to maintain fuel pressure when the engine is off.
  4. MRFOTOS
    MRFOTOS Karting
    May 26, 2003
    232
    Maui, Hi
    I have similar experience...starts up perfectly cold in the morning... then after a drive,and then parked for a while.... now got to crank and crank.. for 45 sec to what seems like 1 min. then fires up realy rough... like only 1 of 2 banks firing.. then about 15 ~ 20 sec later it vroooms up to a normal sound...
    your best bet try replacing the accumulator, did wonders for me
    Mark
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    not to discount any FI issues; first look over your vaccum lines, a leak there can cause similar problems
  6. DGS
    DGS Seven Time F1 World Champ
    73,098
    MidTN
    DGS
    Usually, a vacuum leak would cause a lean mixture all the time, not a rich mixture just when starting.
    I think it's the check valve in the fuel pump that keeps the fuel pressure from bleeding back into the tank when off. The accumulator absorbs surges in fuel pressure from irregular fuel flow between the electric pump and injectors.
    From the symptoms, it sounds like perhaps one of the injectors is leaking: either a CIS injector or the cold start injector. The leaking injector will both bleed pressure off the system, and will flood the intake (or manifold) with excess fuel for the next start. If the car remains off long enough, the excess fuel will evaporate, but the CIS will still have to build up the lost pressure.
    The cold start injector is a regular electric injector, it should remain dry when not electrically activated. The CIS injectors are supposed to cut off when the injection pressure in the individual lines from the fuel distributor fall below a certain level. (On a 328, the injectors open at 3.0 to 4.1 Bar, but I'd guess the 308's injectors are similar. With 2.6 Bar residual pressure, the injectors should be off.)
  7. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    he didn't mention a rich condition just a harad start. i had a vaccum line pop off and it created the same problem. what tipped me off to the location was when i would brake the car would stall and die. then i noticed the incorrect vavle arrangement and the loose vaccum line.
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Please correct this, some people says that the 308 QV GTB/GTS are the same FI system as the 328 and a little different from the 2Valves FI, is this true?
  9. Steve Magnusson
    26,932
    Depends what US model year 308QV:
    1980-1982 US 308i 2-valve = K-Jet without Lambda
    1983 US 308QV = K-Jet without Lambda
    1984-1985 US 308QV = K-Jet with Lambda
    1986-1989 US 328 = K-Jet with Lambda
  10. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    thank you Mine is a 84 GTS QV
  11. DGS
    73,098
    MidTN
    DGS
    Oh, by the way, the "warm-up regulator" is also known as the "control pressure regulator". It's not just for warm-up.
    But the described symptoms sound like leaking injectors to me.
  12. Ago
    Ago Rookie
    May 4, 2006
    23
    Kamloops BC Canada
    Agostino Pietramala
    Yes some of you guys were right Bad accumulater thanks to all
  13. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    So I ok, according to this 1984 to 1989 US are all the same, yes?:)
  14. Ago
    Ago Rookie
    May 4, 2006
    23
    Kamloops BC Canada
    Agostino Pietramala
    Fuel Accumalater Thanks to all
