hard to start my 308 GT4 | FerrariChat
Discussion in 'Technical Q&A' started by rickjaffe, Jul 18, 2010.
  1. rickjaffe
    rickjaffe Formula Junior
    Mar 6, 2005
    363
    houston
    richard jaffe
    It's really hard to start my GT4. changed out the battery. the starter seems like it's engaging, but now most of the time it just won't start. it doens't crank or turn over at all. I know it's not the battery. every once in a while it will turn over, but not consistently. I've noticed it for awhile, but previously it would start after a couple times tuning it on. It's gotten progressively worse, now to the point where it almost never starts . sounds like I need a new starter right?
    I"m hoping it's not a ferrari specific part. anyone out there with a Gt4 (1975) know that part number and where I can get one. I've got an MSD ignitiion system in it.
    thanks,
    rick jaffe
  2. rickjaffe
    Mar 6, 2005
    363
    houston
    richard jaffe
    update: last couple times I tried to start it. after maybe 6-8 attempts got it to turn over and start. could it be a loose wire to the starter? not sure where the starter is on this car? can it be visualized from the top or do I need to look underneath?
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Could easily be an intermittant ignition switch.
    To rule it out - 1975 & later GT4s have a relay in the lower right corner (Q) which is also energized by the same ignition switch wire which feeds the starter solenoid. If you have that relay and it is energized every time the key is placed in 'start' position, then it's not the ignition switch. Assuming you have the relay, when the starter doesn't fire, leave the key switch in the start position for 30-60 seconds and feel for heat in that relay or listen and feel for it to click while going to 'start'.
    Purpose of that 'ignition' relay is to provide full +12v to both coils. Best alternative to the 60 seconds for heat test would have someone reading the coil voltage (red wire) to see if it goes to full voltage in start and then drops to +8V when key goes to 'run' position. Having the MSD complicates things somewhat as I'm not familiar with how they are wired.
    Otherwise it's likely to be the starter solenoid, best accessed from the underside. There are quite a few posts about starter R&R.
    __________________________
    http://www.FerrariDiagrams.com
  4. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,255
    Indiana/North Carolina
    JIM
    I had this same problem with my GT4 a couple years ago. The problem was a loose wire on the starter itself. I ruled out a bad ignition switch too. The starter is difficult to access, best to get the car on a lift or up on jackstands and jacks.
    Good luck!
    JIM
  5. rickjaffe
    Mar 6, 2005
    363
    houston
    richard jaffe
    got a new starter. I looked in my maintenance manual and couldn't find the picture of where the starter is. jacked up the passenger side and removed the rear wheel well cover. can't find the starter. am I looking at the wrong side of the car? I can't see it on the driver's side from above the engine. also I looked at some of the old posts but I couldn't find anything specific as to which side it's on. help?
  6. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    A lot of years passed between yours and mine, but in my 87 mondial the starter is behind the alternator. Passenger side, I remove the wheel and wheel well, crawl in there and look toward the drivers side, it's down low.
  7. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    A search should show threads with pictures, maybe for a non GT4 308. Just search starter removal. Also you could see if the exploded diagram on Ricambi give you direction. I'd start here, someone may have tips or tricks that will be invaluable.
  8. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    The starter end gear engages with the flywheel which is on the left side so remove that wheel well cover and establish the imaginary plane of the flywheel which is covered but obvious. Since you have a new starter, look for a grease covered similarly shaped part in the lower vicinity mounted with it's end at the plane of the flywheel.
  9. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    #9 ME308, Jul 28, 2010
    here is your starter together with the solenoid (no 1)
    look for the heat shield (6) which might "hide" the starter assembly
    lower left, you see the alternator (16)
    hope this helps ;)
  10. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Hey Rick
    You need to download the service and parts manuals from my site. They are invaluable for figuring out where and how things are assembled.
    My GT4 suffered from similar issues, it was a bad connection in the frame end of the ground on the battery (item 42 in above diagram). The wire would wiggle inside the crimped fitting. Bad grounds will also affect starter. How good is the ground strap from engine to frame (when standing at rear of car this is from right rear of transmission to the frame, a flat strap.
    Gerrit
    http://dino308gt4.com
    Have you hugged your car today?
  11. rickjaffe
    Mar 6, 2005
    363
    houston
    richard jaffe
    ok, so I go in through the driver's side (in US) rear wheel well, correct? I tried the passanger side, saw the alternator below the air conditioning compressor, no starter (and I guess no flywheel either). I'll try the driver's side.
    saw one post here that you get to it by removing the back truck lid and the firewall via drilling out rivets. don't want to do that unless there is no other way.
    thanks.
  12. rickjaffe
    Mar 6, 2005
    363
    houston
    richard jaffe
    Have you hugged your car today?[/QUOTE]
    no, but I've been pushing it alot lately (since I can't get it started).
  13. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Rick
    Take a look the the drawing above. The starter is conveniently hidden at front of engine between the block and the front header. Personally I would
    1. Put the car on stands
    2. Disconnect battery!!
    2a. Remove both rear wheels and fender wells
    3. remove alternator
    4. Remove starter, this is NOT fun as the shield is held on by the header nuts. It will come out where the alternator was.
    The starter bolts to the casting where the clutch is. (when peering through LH wheel well, it is on LH side of casting.)
    Gerrit
  14. rickjaffe
    Mar 6, 2005
    363
    houston
    richard jaffe
    why both if it's the starter is on the drivers (left side).
    my alternator is on the right side, but I didn't see the starter there or a heat shield. maybe I'm not seeing it correct.
    I have your workshop manual, but I didn't see the page with the starter in it. (same eyes that's not finding the starter) on the passanger (side right from behind the car)
  15. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    if you already have not done so, check/replace the battery ground cable. mine was really corroded to the frame. i also replaced the engine gnd strap to the frame. and clean those contact surfaces before installing new cables. this made a world of difference in my 308 as far as lights, windows, guages and starting...
  16. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    If you remove the alternator and reach past where the alternator used to be, keep going to the opposite side of the engine, from passenger to drivers, and your hand will run into the starter. It's tucked in there so you can't see it or get it out. It's designed that way.
  17. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Hi Rick
    you have to open a space to get the starter physically out of its hiding spot, thus the removal of the alternator. Your alternative is removing the header which I can say from experience is not an easy task.
    I'll try to find a pic of the location but in the end, the best/only way to find it is to put the car on stands and look up with a good light. You will not see it from the drivers side wheel well, but you could feel it from there between headers and block.
    Gerrit
  18. rickjaffe
    Mar 6, 2005
    363
    houston
    richard jaffe
    might be too complicated for me. I don't like going under the car with like 10 inch blocks. wish I had a proper lift at home.
    one thread you go in by removing the firewall. I assume that's not necessary.
  19. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    No drilling, from the bottom and sides only.
    Seriously, buy some good stands, you have a solid frame to put them under. Don't use concrete or wood, not predictable when they will split.
    I never liked being under my Alfa or Golf or Passat, no real frame. Loved being under the Ferrari though. Plus easy to hug it from underneath :)
    Gerrit
