Hard top stuck at opening | FerrariChat
Discussion in 'Technical Q&A' started by Kishko, May 18, 2023.
  1. Kishko
    Kishko Rookie
    Sep 14, 2020
    1
    Kish Ko
  2. Andynyc
    Andynyc Formula Junior
    Apr 20, 2017
    291
    NYC!
    In my experience it means the battery is not charged enough to operate the top completely yet. Either leave it on the charger for a while first , or drive it for 30 minutes and then try opening the top.
    LARRYH likes this.
  3. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Crystal Lake, Illinois
    Alex
    Were you able to open the top?
  4. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,231
    Georgia
    Wade Williams
    I always run the top with the engine running. If it is stopped mid cycle it usually means a switch did not trip and the system thinks it has not completed the needed step to continue. I diagnostic scan will show what is happening and what the system is not seeing. Pretty common issue. I wish I could tell you which one, but you should have it scanned so you are not throwing part sat it.
    alex likes this.
  5. garybobileff
    garybobileff Formula 3
    Sponsor
    Feb 5, 2004
    1,181
    San Diego CA
    Gary
    Replace the elastics in the top.
    Gary Bobileff
  6. Motob
    Motob Formula 3
    Nov 11, 2003
    2,389
    Frederick, Maryland
    Brian Brown
    One of the top position sensors has most likely gone bad. If the top ECU does not know the position of all of the components, it will stop working to prevent damage to the roof. You must use a Ferrari capable scan tool to check for faults and function of all position sensors. You can purchase them individually and splice them into the harness. They go bad all the time, and they are fairly easy to replace.
    Brian Brown
    Grand Touring Enterprises
    Frederick MD
