Hard water deposits on windshield | FerrariChat
Discussion in 'Detailing & Showroom' started by MVDESQ, Oct 7, 2022.
  1. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Matthew & Kristen V.
    We have a car with white hard water deposits on the windshield that seem baked in. We suspect it is from a sprinkler line leak. We have tried white vinegar, bar keeper’s friend, clr, and lime away. They did nothing. We bought and used Invisible Glass - Glass Stripper. It helped and removed 75% of the deposits but it is still there. Any ideas how to remove it completely?
  2. colorfull
    colorfull Formula 3
    2,281
    Franklin Park, New Jersey
    John Napoli
    I have actually had hydrogen peroxide and baking soda remove more than any of those
    Keep it moist, let it sit for hours, elbow grease
    MVDESQ likes this.
  3. Use some WD-40
  4. DiamondDog
    DiamondDog Formula 3
    Aug 29, 2021
    1,422
    Orange County, CA
    MVDESQ likes this.
  5. Edward 96GTS
    Edward 96GTS F1 World Champ
    10,853
    Ed Fred calcium remover.
  6. GTO Joe
    GTO Joe Formula Junior
    997
    Charlotte, NC
    Joseph Troutwine
    Tried most of what is mentioned above and then bought a Car Pro glass polishing kit that you use with a R/O buffer. Makes fast work of the spots and glass shines.
  7. DiamondDog
    Aug 29, 2021
    1,422
    Orange County, CA
    Jaxwax I aving a 20 percent off sale right now. I’m not afflicted with them, just like a lot of their products
  8. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,481
    New Jersey
    Griot’s sells “Glass Polish” and you use a little white pad with it that they offer as well, often in a kit. You can do this by hand, no need for orbitals. That might be a very good solution. I even use this stuff on shower doors to get them crystal clear from soap.
  9. racerboy9
    racerboy9 F1 Rookie
    2,632
    I just went over all of the glass in my 1995 Mercedes with a single sided razor blade after I thoroughly cleaned them. Amazing what you get off. Rough on the first pass and smooth on the second pass. Probably used six blades for the whole car.
  10. Kyle Stoffer
    Kyle Stoffer Karting
    Sep 23, 2019
    82
    Kyle R Stoffer
    I use products from a company called 3D out of Santa Clarita California…absolutely amazing stuff. They are a professional detailer supplier so not a lot of focus on the DIY market.
    They make a product called Eraser Gel that will take water spots off any paint or glass.
    Someone already mentioned it, but 3D also makes a glass polish that would work, but from what I understand it requires a buffer and some skill, designed more for the professional.
    www.3Dproducts.com
