Hard wiring a radar detector on a 308 | FerrariChat
Discussion in 'Technical Q&A' started by Whiskeyman, Apr 5, 2007.
  1. Whiskeyman
    Whiskeyman Rookie
    Jan 28, 2007
    31
    West Chester, OH.
    Mike Calvert
    I plan to buy and hard wire a Escort or Beltronics Radar Detector.
    What is the best fuse to tap on to.
    Thanks for your help in advance.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    Mike, this what I sugest, for the 12v. power wire just use an inline fuse holder that you can buy from a Radio Shack and put a 3 to 5 amp of fuse, it's the simplest thing to do.
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I don't know why you wouldn't want to get a Valentine One after reading al over FChat that it is BY FAR considered the best, but in any case, if you're going to hardwire a detector into your QV, the easiest place is to pull out your dome light assembly to access the wires in there. That's how I wired in my Valentine.
  4. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Wire it to a circuit that is only hot when the ignition is on.
    Leave the switch on the detector in the on position all of the time.
    That way, the detector will automatically come on when the car is running, and turn off when not.
    You won't have to remember to manually turn it on and off.
  5. walawdog
    walawdog Formula Junior
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    Are you mounting a hidden unit with a remote sensor type set up? I bought a wireless unit from the close out at CompUsa, so, just recharge and go.
  6. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Left fuse box - left 3 positions A, B, C are powered at the top by the ignition switch when in 'Run' position. Next fuses, D E at top are powered by the ignition switch in "Accessories' position.
    I suggest making your choice from these two possibilities. You may need to purchase (Shucks, AutoZone etc) a brass splitter to enable 2 push-on connectors to attach to where a singe push-on connector now resides. The detector will come with a fuse holder or at least a recommendation for fuse size.
    And remember, your eyes, brain, wisdom and some prudence are better ticket avoiders than any radar detector can everl be.
  7. 330gt
    330gt Formula 3
    Nov 12, 2004
    2,096
    Seattle, WA
    Kerry Chesbro
    I used the fuse with the electric fuel pump. That was the detector is on only when the ignition is on but doesn't go off when starting. I find it annoying to have a detector go thru its beeps first when you turn on the ignition and then when you try and start the car.
    Be sure and use an inline fuse (usually supplied with the detector hard wiring). You don't want a problem with the detector or wiring to blow the fuel pump fuse.
