Has anoyone tried powering their Valentine One with the ODB port? | FerrariChat
Discussion in '360/430' started by CoreyNJ, Mar 18, 2024.
  1. CoreyNJ
    CoreyNJ Formula 3
    2,476
    New Jersey Shore
  2. GogglesPisano
    GogglesPisano F1 Rookie
    3,217
    East Bay, California
    Joe
    I wouldn't want to be the guinea pig on this one. There's probably little risk associated with it, but hooking it up to a switched power from the head unit is not that hard either. Or a fuse tap to something that's not critical.
    robertjskelton likes this.
  3. jerbear27
    jerbear27 Formula Junior
    300
    CT
    Jeremy
    I went with the switched power from the head unit. I tried to wire it to the airbag light in the overhead console/dome light area and all I got was an airbag light on the dash and some weird behavior with the detector not powering on. Thinking there is a difference between my ‘08 and previous years with that wiring.
    Pretty easy to get the wiring across the headliner and down the a-pillar.
  4. Qavion
    Qavion F1 World Champ
    14,332
    Ian Riddell
    The OBD port is powered by a 10 amp fuse (live battery power, not switched). Note that there are other devices attached to that fuse (TPMS and eDiff)
    Would you be turning off the detector (if possible) at the end of a trip?
    I'm not sure what the power outputs of that Savvy device are.
    Do you mean you tried to wire your radar detector into the Airbag warning light (supply) or just the detector warning light? The warning light has 4 contacts. How did you figure out how to wire it up?
  5. jerbear27
    300
    CT
    Jeremy
    Airbag warning light supply.
    I was following some previous posts here. Following those instructions got me nowhere. The wiring matched, but the radar detector did not turn on. Ended up with the airbag light on on the dash. Ended up wiring it to switched power for the radio.
    Qavion likes this.
  6. CoreyNJ
    CoreyNJ Formula 3
    2,476
    New Jersey Shore
    How did you tap into the switched power? Did you create a new harness, add pins to the existing harness or just tap the wires?
  7. Qavion
    14,332
    Ian Riddell
    Thanks. I'd imagine you'd wire it up in parallel with pins 2 and 3, but the earth and power wires look quite small. Not your usual 0.5m^2 size.
    I guess the Airbag ECU picked up a change in resistance in the circuit.
  8. jerbear27
    300
    CT
    Jeremy
    I have an aftermarket head unit in the car, so I just spliced into the 12v switched power wire using a solder connector. Didn’t take a picture of it or I’d post it.
  9. jerbear27
    300
    CT
    Jeremy
    Instructions I found were the orange wire was 12v switched power and black was ground. Didn’t work for me.
  10. Qavion
    14,332
    Ian Riddell
    #10 Qavion, Mar 18, 2024
    The orange/white wire will be a signal wire from the Airbag ECU to turn on the light when the disable key is used. It's not ignition key power. The signal wire could even be a ground. You'd have to know the internal circuitry.
    Full Airbag Wiring Diagram here:
    https://www.dropbox.com/t/OjwBXc67KlRYkxQF
    jerbear27 likes this.
  11. jerbear27
    300
    CT
    Jeremy
    Thanks for posting!
    Qavion likes this.
