Has anybody dyno their 430? | FerrariChat
Discussion in '360/430' started by CRG125, Aug 16, 2006.
  1. CRG125
    CRG125 F1 Rookie
    Feb 7, 2005
    2,640
    Los Angeles, Ca
    Vivek
    So has anbody dyno their 430? What kind of numbers did you get?
  2. SP_wEaZeL
    SP_wEaZeL Formula Junior
    Aug 23, 2004
    367
    Yes, we have dynoed both F1 and 6-speed.
    F1 - 430 RWHP
    6spd - 420 RWHP
    Not sure if F1 really makes a difference but those are the numbers we got. I'll double check the 6 spd dyno in the morning..but i'm almost positive it was 420+- a couple HP.
  3. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Wow! :) Thats impressive HP numbers at the wheels, considering they only have 490HP at the flywheel. :) 400HP+ at the bags would be awesome fun. :p
  4. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    What type of dyno was it?
  5. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    Since the drivetrain is mechanically identical the difference must be in the engines.
    Gary
  6. derek a
    derek a Formula Junior
    Sep 17, 2004
    590
    CA OR
    Derek
    That difference is less than 3%. Unless you ran the cars back to back differences in weather conditions could have accounted for that. Other test conditions could also have contributed to differences.
  7. stoopsdude
    stoopsdude Karting
    Jul 1, 2006
    157
    Westport, CT
    exactly.. the only difference should be the testing conditions.. or the driver
  8. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Thats right mate. :) Hotter or colder weather.....Is the fuel in the tank stale compared to the other car....ect...ect....Also comes down to the driver. The engine are exactly the same GARYF. When I dynoed my 348, we did 6 ramp runs, and they were all very very close, give or take a few HP. They were done 6, in a row. The heat soak was obvious, as it lost a few HP on the last 2 ramp runs. The 1st 2 ramp runs, pulled the highest HP figure. :)
  9. SP_wEaZeL
    Aug 23, 2004
    367
    2WD Dynojet.
    I went back to the dyno to recheck the numbers:
    6speed: 424.6 RWHP / 305.2 FTLBS. TRQ (72.6 Degrees Farenheight)
    F1: 432.3 RWHP / 304.4 FTLBS. TRQ (74.6 Degrees Farenheight)
    Dynos were not done on the same day.
  10. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    What I meant was there are bound to be some engines slightly stronger than others off the assembly line. Since there is no difference between the gearboxes that must be where the discrepancy is, much more likely to be power differences between engines than power differences between identical gearboxes.
    Gary
  11. SP_wEaZeL
    Aug 23, 2004
    367
    I totally agree with you on that. Even if it's the same motor, it is possible that one might make more power then the other. It's just how it goes. The difference in power between the 2 cars was a few HP, but nothing major. If it was anything more then 10/15 RWHP..then I would be concerned. Just how the dice roll sometimes.
  12. RobHulme
    RobHulme Karting
    Mar 13, 2005
    53
    I have dynoed my 6 sp 430 and got 342hp at 8250hp in 4th gear at the wheels at our altitude of 1500m which means a drop of 17% on sea level figures ie equates to 410hp at sea level. Temperature was about 70 degrees F. My technician seemed to think that the results were pretty good for a car rated at 490hp. He also tested fuels timing etc and found them to be spot on. My 1998 355 spider with Tubi and optimised piggy back computer pushed 259hp some 7 years ago when we tested it on the same Dyno.
    What gear did you run the tests in and how high above sea level were you? I also assume that you were running standard air pressures in the rear tires
  13. PAP 348
    Dec 10, 2005
    100,220
    Pap
    I get ya now mate. They can vary for sure. :)
  14. rscholl
    rscholl Formula Junior
    Dec 4, 2003
    296
    Houston,TX
    Are those numbers corrected or raw?
    Thanks.
  15. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    #15 chaa, Aug 17, 2006
  16. Mbutner
    Mbutner Formula 3
    Aug 11, 2005
    1,689
    Bay Area / Washington DC
    Quick Draw
    Wow, that 430 dwarfs the 355...
  17. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    #17 chaa, Aug 17, 2006
  18. SP_wEaZeL
    Aug 23, 2004
    367
    SAE corrected.
  19. rscholl
    Dec 4, 2003
    296
    Houston,TX
    Thanks.
