Has anyone had the dreaded transaxle/diff failure? | Page 3 | FerrariChat
Discussion in 'Boxers/TR/M' started by stevel48, Dec 12, 2006.
  1. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    From a related thread on the TR in another forum area:
    http://www.ferrarichat.com/forum/showthread.php?t=112201&page=4
  2. AmoCS
    AmoCS Formula Junior
    Mar 20, 2006
    386
    Amo
    Hi,
    This is very interesting information.
    My car is a late 1994 512tr, and I've been wondering what mods it might have had compared to earlier models, as the air boxes are black, just like the "M".
    Is there a list of these service bulletins available on the internet?
    From the above bulletins, my car has a later engine, where is the s/n on the gearbox pls?
    Thanks for the info
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    See post # 49.
  4. rjnavion
    rjnavion Karting
    Nov 1, 2003
    128
    Gate, OK (western O
    Ron Judy
    The Parts Catalog has drawings indicating where to find the various serial numbers. Without going out and looking at the car I'll try to give enough description where you can find the numbers. I didn't have too much trouble locating them.
    GEARBOX: On the back casting, lower left corner looking forward. Numbers found on mine were 124859 and N314. The long number didn't jive with any number breaks in the parts book and the 314 did, so I assume that is my gearbox SN.
    ENGINE: Under part of the air cleaner duct on right side. The removeable perforated plate on the clutch housing is near it in the picture.
    ASSEMBLY NUMBER: On a frame member between a canister with a bent tubing coming out the top and a rectangular expandable duct.
    VIN NUMBER: Found many places in the car but this one is in the engine compartment on right upper frame rail near the above canister (believe it's a fuel filter).
    Amo512TR you're lucky; since your car is a 1994 model I believe you have all of the updates that carried over to the 512M, but there may be more that I don't know about. There are many improvements over my 1992 model; some are in the form of Service Bulletins and others simply changes that show up in the parts catalog. If you have a 1994 parts catalog and study it carefully, line by line, every production update will be there by serial number of the various engine/drivetrain components.
    I don't know where on the internet you could get the SB's. A top Ferrari technician was kind enough to FAX me copies of those involving the transmission and differential. Other than the ones mentioned in my post #49 are SB30-16, casehardened ring nuts in trans; SB30-17A, ring nuts in trans; SB30-21, springs on synchronizers; SB30-22, reverse idler gear shaft; SB30-20, oil line between gearbox and clutch bell housing.
    Several years ago I ran into another one involving an update to the clutch slave cylinder and throwout bearing. I'll have to dig through my records to find the number; a member in the UK posted a copy of it when I was having slave cyl. trouble. I'll look for this old post and copy it in another message.
    If someone needs these SB's I'll be glad to FAX or mail them. I don't have a scanner, besides the mass of paper would overload the thread. Others have been helpful in furnishing me with information and the least I can do it help other owners.
    Ron
  5. AmoCS
    Mar 20, 2006
    386
    Amo
    Thanks Ron.
    I know my engine no, it was the gearbox no which I could not find.
    Can u see it from the top if you open up the engine hood?
    My motors a Dec94 model, engine no is just under the 37000 mark.
    It's great to know that my car has had the 512m mods, I've always wondered it had, but no one could confirm it.
  6. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    No you cant, look under the car at the left rear corner of the gearbox. Cant miss it.
  7. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    Can anyone tell me if the F512M transmission can bolt directly onto a 91 TR or will I have to make other changes to the car?
    And if anyone has a line on an F512M transmission, please post or PM me ;)
  8. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,537
    Tuscaloosa, AL
    Drew Altemara
    David, why not buy the updated differential from T Rutlands. Then send your box together with the updated differential (and anyother parts like syncros you might think of changing) to Rod Drew in Ca and let him put the thing together and ship it back.
    Just a thought.
  9. UnVinRougeSVP
    UnVinRougeSVP Karting
    Jan 27, 2004
    117
    Southeastern PA
    Ted
    Regarding post #51, does that apply to the Boxer as well? Can the diff be removed/replaced/adjusted through the side covers with the engine in situ?
  10. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Yes it can.
  11. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Yes, and while you're at it, use the opportunity to replace the shift shaft seals, at the very least.
  12. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    How can you properly reshim and set the lash for the ring and pinion this way?
    From what I understand its critical or you will destroy the R&P quickly if not set up perfectly
  13. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    Waiting to hear from TRutlands - T is on vacation at the moment. Thanks ;)
  14. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    If you're just changing the diff itself due to cracking etc, and re-using the undamaged existing ring/pinion.... setting bearing preload and mesh is very easy, and quite often minimal changes if any are required... the diff and bearings seem more uniformly made than ring/pinions...
    to set bearing preload, do this with the ring removed, just bolt the diff up tight with a spacer if necessary.... then, once this is done (with consideration to mesh)... THEN check the mesh and shim BOTH sides of the diff bearing if necessary...
    If the pinion height was correct before the diff failure, it will be after... it'll only be diff/bearing manufacturing tolerance that you need to adjust for, to make the ring mesh properly again....
    In my experience.. bearings ALWAYS go straight in, straight swap, no messing about... and diff's themselves are usually very good....
  15. JTR
    JTR Formula 3
    Apr 26, 2005
    1,502
    in a house
    Maybe I’m missing something here, or just dumb, but if the 2-piece welded carrier cracking is causing all the problems, why not just pull it out and have a good welder do a proper re-welding to prevent it from cracking?
    Welding has come a long ways in the past 25 years.
    Maybe the ring gear mounting surface would take a little truing up, but it seems to me that this would be a good deal less expensive than replacing the carrier with a newer unit, or waiting to rebuild the gearbox.
  16. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Because of the potential damage a part like this can cause, and because these cars are so darned expensive, I think of them like aircraft. Now if this were an aircraft part, there is NO WAY the FAA or even the old CAA would have allowed a part like that to be welded. It should have never been welded in the first place. The basic problem is that the very act of welding stresses the area, and its always made cracking easy along a weld. Welding may have come a long way, but you still cant weld on crankshafts, etc. You can on a Chevy, but its totally illegal on a Cessna. Why risk it on a Ferrari?
  17. boxerman
    boxerman F1 World Champ
    19,915
    FL
    Sean
    So where do I get a "better non weleded" diff carrier for a boxer and one of those titaniaum twirl shafts. Seems like a worthwhile excercise when I am doing the eo next year.
    Going to do some head work cams and an efi, + suspension rebuild. Are there adjustable shocks available for these cars.
    Anyway this should lead to a relatively bulletproof hard charging streetable boxer.
    Any ideas where to find the tranny upgrade bits?.
  18. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,739
    NYC
    Buzz
    Head work cams and EFI? Sounds like you caught my disease. I had an extensive dialogue with the guys at Carobu in Costa Mesa about this. It's doable but it's expensive and it smacks the value of the car. Newman had a novel idea: get a wrecked TR 4v engine and work it into the Boxer.
  19. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Frank Capo, Modena Engineering here in Melbourne... he's made 100's and ships them all over the world.
    I've used his 360 ones extensively (very similar to BB)... they're heavy but tough
    I think Rob Schmer????horn "rexcr"? is an agent for you guys over there...
  20. SPEEDMAN WITHOUT LICENCE
    SPEEDMAN WITHOUT LICENCE Formula Junior
    Jul 7, 2006
    486
    Charleroi Belgium
    Stefaan Wauters
    Hi,
    Any adress,phone n° or internet site?
    Idea about the cost of a titanium shaft?
    Speedman
  21. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    rexcr is a site sponsor... deltaV or something...
    edit...
    http://www.deltavee.net/
  22. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  23. markpeboxer
    markpeboxer Formula Junior
    Jul 1, 2006
    254
    Chicago
    Mark
    I contacted them and got a quote of $11,500 for both trans and diff.
  24. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    trutlands has 512TR gearboxes ready to go for $14500.00, ouch.
  25. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
    Is that deltavee?
