Has anyone lowered their Mondial? | FerrariChat
Discussion in 'Mondial' started by Scaledetails, Dec 13, 2008.
  1. Scaledetails
    Scaledetails F1 Rookie
    Nov 19, 2003
    4,211
    Daytona Beach, FL
    Stephane
    Has anyone lowered their Mondial? How is it done? I may want to lower mine an inch, but not sure where to start, any advice would help, thanks.
  2. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,762
    US of A
    Michael
    Your "t" has height adjustable suspension. Look to each wheel well and see the shock tube. It is threaded (like a racecar) and the spring perch can be turned down to the lowest point if you want to go low (of course you would want an alignment & possibly a corner balance while your at it).
    Just another example of how the Mondial "t" is a special car.
  3. Scaledetails
    Nov 19, 2003
    4,211
    Daytona Beach, FL
    Stephane
    Wow! Thanks Michael, I will look into that.
  4. mwr4440
    57,946
    Bavaria, The 'Other' Germany
    Mark W.R.
    Talk to Russ (snj5).
    He has a Mondi 3.2 and I think he mentioned that he lowered it somewhat when I met him in Kaiserslautern, Germany last weekend.
  5. WilyB
    WilyB F1 Rookie
    4,272
    AZ
    Absolutely correct on all counts! :)
  6. JF308
    JF308 Formula 3
    Jan 17, 2007
    1,263
    Boulder, CO
    John Feeney
    I think you'd enter the "NO SPEED BUMP" zone if it were to be lowered. It'll look great, but be cautious afterwards...
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #7 snj5, Dec 13, 2008
    Yes - I lowered my 3.2; I think your t can be lowered without much trouble. I got a Koni setup from Sponsor Carobu and lowered mine. There is a thread buried deep in the technical section about it somewheres.
  8. effer
    effer Formula Junior
    Jan 6, 2004
    814
    near Montréal
    François R.
    And what is the title of this deep buried thread?
    I ask because I want to lower my 3.2.
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
  10. effer
    Jan 6, 2004
    814
    near Montréal
    François R.
    #10 effer, Dec 14, 2008
    Thanks snj5!
    Can you post pics from side view of your lowered Mondial? From what I've read, you did a one inch drop, isn't it?
    How is the handling improvement with stiffer springs? Do you have rubbing issues?
  11. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #11 snj5, Dec 14, 2008
    About a one inch drop; Only rubbing issue is if there is a sharp break and decline in the road then the middle might rub due to the longer wheel base, but rare. Can be avoided by taking sharp breaks at an angle. I stiffened the back to make the handling a little more on the nose and less understeer, and I like it. I could have gone way way stiffer on the springs, but I do like the ride on trips and do not track the car. It is about perfect for a street small GT, at least for me.
    Again as is my soapbox, it is important not to over-tire the car with large section tires. max on the rear should be no more than 245 and on the front 225; mins should be the factory recommended 225 rear and 205 front which work fine with the stock power available. I opted for 205 front and 235 rear PS2 since mine has a wee bit more power.
