having brake rotors turned | FerrariChat
Discussion in '360/430' started by [email protected], Aug 14, 2017.
  1. rhall@mtuinc.com
    Jan 2, 2014
    16
    I've got a 2004 360 Spider with 18K that could use brakes. Anyone had a bad experience having the rotors turned once rather that replaced.
  2. mello
    mello F1 Veteran
    5,493
    CA Bay Area
    Steve
    I did my brakes at 18K with turned rotors. Works fine.
  3. RedNeck
    RedNeck F1 World Champ
    12,345
    The CSA
    Me
    It depends on how far in spec they are. Turning rotors is fine to a point, it's just a simple disc brake system, nothing special at all. Nothing. In fact it's really not that great. That being said, I just replaced all 4 rotors for under $400, so if turning rotors isn't an option, replacing isn't that big of a deal.
  4. rhall@mtuinc.com
    Jan 2, 2014
    16
    Where did you get four rotors for $400.00? OEM?
  5. RedTaxi
    RedTaxi F1 Rookie
    3,340
    New Zealand
    Glen
    Yes I would like to know too. I saw 2 rotors OEM on ebay for $900. No one would turn rotors if they were only $100 each.
  6. rhall@mtuinc.com
    Jan 2, 2014
    16
    The problem with the rotors are that they are drilled and no one likes or will turn/machine drilled rotors.
  7. RedNeck
    12,345
    The CSA
    Me
    Our OEM discs are Brembo 09.7267.50. Search by the Brembo part number
  8. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Why try to save money on the brake system ? Your life depends on it !
  9. f355spider
    f355spider F1 World Champ
    18,047
    I've never had a problem...maybe just me?
  10. RedTaxi
    RedTaxi F1 Rookie
    3,340
    New Zealand
    Glen
    Oops I was looking at 430 rotors. Seems they are way more expensive.
  11. RedTaxi
    RedTaxi F1 Rookie
    3,340
    New Zealand
    Glen
    I will be having a go too. They are just cast iron, the holes make no difference.
  12. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I've never had a problem with turned rotors on my 360. That said, once I wore out my fronts, I went with StopTech replacements at around $1050 for the pair. They are better than stock (big surprise), as they are the "floating" type. The rears are still good and were turned with the last pad replacement. They probably will need replacement next time around, and I'll go with StopTechs again (car uses same rotors front and rear).
    https://www.zeckhausen.com/catalog/product_info.php?cPath=230_995&products_id=4778
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Superperformance do brembo discs 182606 @ £75 each so why would you machine them
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    No reason you cannot machine drilled discs
  15. RedNeck
    12,345
    The CSA
    Me
    Same price. See below.
    Exactly.
  16. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,117
    Calif
    Brett
    It also depends on whether the shop has their machine in spec. Most don't consistently tune their machines...
