Having problem with the cel | FerrariChat
Discussion in '360/430' started by keisuko, Dec 1, 2011.
  1. keisuko
    keisuko Rookie
    Dec 2, 2010
    26
    hard to drive when the gear in low rpm but when up till 3k that will have the power.....after a few miles that the cel when out and i check it with tester that get the fault of catalytic converter protection,do anyone happen this before,im using capristo exh.
  2. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    What actual code did you have?
    Were you getting a "Slow Down" warning on your multifunction display? Sounds like your system thinks the CAT is getting over-hot and is putting the car into slow down mode to protect it.
    You may have an over hot cat or it may be a faulty detection.
    How long ago did the Capristo exhaust go on the car and has it been perfect since then (i.e. no problems, no codes)?
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,528
    Charleston, SC
    Curt
    keisuko, agree with greg above. Can you be more specific as to exactly what codes you are getting? Could be a bad coil, could be an issue with the capristo...
  4. keisuko
    keisuko Rookie
    Dec 2, 2010
    26
    P1104 air flow meter:low
    P0300 multiple misfiring
    P0308 major emission
    P1454 cat converter protection
    Using capristo for 1 year half already,all in nice condition....
    Im driving a manual gear
  5. Tio
    Tio Formula Junior
    Mar 26, 2011
    391
    London
    Harry
    Sounds like the problem might be starting from the air intake end and working it's way through.
    I would check the air filters ( you are not using K&N or BMC, their oil might have fouled the MAS), and also try to the the air flow sensors cleaned with a mild window cleaner and then dry them using a hairdryer but not with a heat setting.
    Once you have done this try to reset the error codes and see what happens next.
