My hazard/emergency light only works on the driver side (left) both front and rear, and nothing on the passenger side. But turn signal works fine on both sides. Is it the relay? It cant be the bulbs cause the turn signals work. Can someone help please, thanks.
Check the hazard switch and the wires connected to it. Maybe some of them are loose. Check also the switch in itself; maybe the internal connections are worn. For sure the bulbs are OK.
