Hazard Switch 1987 328 | FerrariChat
Discussion in '308/328' started by gsbarr, Feb 24, 2010.
  1. gsbarr
    gsbarr Karting
    Feb 23, 2005
    68
    My hazard light switch as well as my front and back lights continue to blink even after I turn the ignition switch off. Can't seem to get the hazard switch to turn off. I removed the fuse but now the turn signals won't work.
  2. PT 328
    PT 328 F1 Rookie
    4,005
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Many cars have hazards work with ignition off but turn indicators require
    ignition on...so they are separate circuits but feed the same lights.
    Which is why the turn signal wiring passes through the hazard switch.
    Hazard fuse also power Cigar Lighter, Antenna, Parking lights
    Whereas Turn Indicator fuse is Left Box has also stop rear lights.
    So you should be able to disable hazard by removing the fuse
    and not disturb the turn sigs...for driving until you find the problem.
    Seems to me someone had similar problem recently but didn't post the fix.
  4. gsbarr
    gsbarr Karting
    Feb 23, 2005
    68
    I tried the fuse thing, but as you said the wiring passes through the hazard switch so if it isn't live, the turn signals don't work.
    Gary
